Hydraulic problem on lotus car
mycadcae
Help for information about hydraulic problem on lotus car ...
Regard,
Nik Wan, Mechanical Designer, CATIA V5/ Solidworks/Autodesk Inventor/ AutoCAD
Re: Hydraulic problem on lotus car
Quick sumup of Hydraulic actuation in f1 by moog:
Ultralight servohydraulics for Formula 1
April 13, 2006
Kenneth J. Korane
Hydraulics is noted for packing a lot of power into compact packages, and today's Formula 1 racing cars are taking advantage of this feature with great success.
Printer-friendly version
Edited by Kenneth Korane
The E024 servovalve weighs 92 gm, is rated for 7.5-lpm flow at 70 bar, with maximum pressure of 210 bar. On F1 cars, it handles high-power applications such as shifting gears and actuating clutches.
Over the past two decades, F1 cars have incorporated sophisticated hydraulic systems to handle a range of applications, including ABS and power-assisted braking; clutch, gearbox, and throttle actuation; and controlling engine air inlets and active suspensions.
Moog Inc.'s facility in the United Kingdom (moog.com/industrial), first supplied the F1 industry with custom versions of miniature servovalves used on aircraft, missiles, and spacecraft. But these were soon replaced by products tailored to the rigors of F1.
One key demand of motorsport engineering is designing for absolutely minimum weight, according to Martin Jones, the company's motorsport market manager. "The weight-watching culture is particularly prevalent in F1, where much effort is expended to shave a few grams from even the smallest components," says Jones. Curiously, all current F1 cars carry ballast to achieve the minimum allowed weight of 600 kg. However, teams can gain considerable competitive advantage by maximizing the ballast and placing it low in the vehicle, which aids handling, explains Jones. It also facilitates on-track setup procedures, as moving the mass fore or aft alters the vehicle center of gravity.
"Hydraulics is absolutely unique in terms of power density, and the little valves we supply to F1 can control 5 hp (3.5 kW) of power at a fraction of the size and weight of equivalent electric motors," says Jones.
Moog's E024 subminiature servovalves, for instance, weigh only 92 gm, less than half the mass of the company's smallest aerospace servovalve. In today's F1 cars they're typically used on the clutch, gearshift, throttle, and differential.
The valves' small size — the E024's spool has a 4-mm diameter — and steel construction permits thin walls without excessive internal stresses, even at 280 bar. This lets designers build in a significant safety factor with minimum impact on weight.
Valve drivers in the car's ECU (electronic control unit) supply a ±10-mA current signal that is varied to produce a proportional valve response. An electric torque motor that rotates ±2° drives the pilot stage. Considerable design effort on details such as the inertia of moving parts, magnetic field strength, and air gaps results in a response time of <1 msec for the electromagnetic stage, explains Jones. It controls the tiny secondstage spool, giving total step response of 2.8 msec — extremely fast for a hydraulic servovalve.
Heat is another issue. F1 hydraulics generally operate at temperatures to 135°C, versus about 60°C on typical industrial systems. In any hydraulic circuit, throttling flow generates heat. But most industrial systems include large reservoirs to dissipate the heat. In contrast, F1 hydraulic reservoirs hold only 20 to 30 cc. With no significant oil mass in the system, temperature rises quickly.
Air coolers could be used to keep hydraulic temperatures down, but that adds weight and creates aerodynamic drag. Instead, valves are built to handle the heat. High-temperature Viton seals are the norm, and components are held to extremely tight tolerances.
One consequence of high temperatures is low oil viscosity. Compared with industrial hydraulic fluid that runs in the 20-CSt range, F1 hydraulics have a viscosity of 3 to 4 CSt at 135°C. As a result, any large clearances in the valve will generate internal fluid leakage, energy losses, and heat. To counteract these effects, radial clearance between the valve spool and body is only 1.25 m.
Systems normally rely on high-temperature, flame-resistant aircraft hydraulic fluids. Engine coolant at 110°C is often used to cool the hydraulics via a liquid-toliquid heat exchanger.
Servovalves are typically serviced every 4,000 km — or about 20 hr of operation — and retired after 12,000 km. Maintenance involves dismantling and visually inspecting all components. Technicians replace all O-rings, a tiny 10- m filter inside the valve (that protects against hard-over failure from stray contamination), and a thin-wall, stainless-steel tube in the pilot stage which has a finite fatigue life.
Some car functions require only on-off hydraulic control. These include engaging reverse gear and opening the "cat-flap," an access door to the fuel filler. F1 cars also include a special safety feature, the clutch-disengagement system, used after accidents or breakdowns. Pressing a red button on the dashboard dumps oil stored in an accumulator into the clutch slave cylinder, which opens the clutch and permits race marshals to push the car off the circuit.
For these applications, Moog developed the E050-747 microsolenoid valve. The three-way, normally closed, two-position valve weighs less than 40 gm, making it one of the smallest direct-acting hydraulic solenoid valves available, says Jones.
Another application of note, says Jones, is power steering. Although F1 cars are light, they experience nearly 3 g of downforce at high speeds. They also have extreme steering geometries with large caster angles, which lifts or lowers the front end as the steering wheel turns. This makes the cars essentially undriveable without power steering.
A rules change several years ago banned electrohydraulic power steering (in what was reported as an economizing move). This forced teams to revert to hydromechanical control, for which Moog developed a precision rotary power-steering valve. It features two concentric sleeves connected by a torsion bar in the load path of the steering column. Torque applied in either direction rotates the inner and outer sleeves relative to each other. This, in turn, opens flow-metering ports that direct high-pressure oil to one side of the assist actuator. Closed-center operation minimizes energy consumption and offers high accuracy and repeatability. The valve generates high flow with small angular inputs, giving high steering stiffness and virtually instant response.
"Effectively, we've made a miniaturized version of a road-car power-steering system, but it runs at 200 bar and is much more energy efficient. It's a passive hydromechanical device, with no electronic-control inputs," says Jones.
In addition to F1, other racing circuits have also embraced hydraulics. Rally cars, for instance, use servovalves for transmission control and on suspensions to improve traction and handling on a variety of road surfaces. In these instances, miniature, high-response servovalves must survive extreme environmental demands. The tiny E024 valves have also made hydraulic control possible on motorcycles, and are expected to soon appear on Moto GP bikes. Future motorsport developments will likely include more energy-efficient hydraulics and even lighter actuators.
so we got :the brake system hydraulics ...completely separate system
the steering system ..separate completly fluidhydraulic system
the gearshift and clutch actuation system with moog servovalves.
lotus have had troble withthe steering ,quite at the beginning ,but i think the main problem seems to be the gearshift/clutch system.
the question is now is the pump providing the oilpressure and volume to operate the gearshift transmission or engine mounted and is it supplied by Cosworth or Xtrac in their deal?
Edis
Edis
59
marcush. wrote:so we got :the brake system hydraulics ...completely separate system
The servosteering is part of the same hydraulic system as the clutch, gearshift and throttle. It's a aerospace type pump with a closed hydraulic system operating at 210 bar. The pump is engine mounted and is of the variable displacement swash plate pump type. The hydraulis system also have and a hydraulic accumulator.
xpensive
xpensive
214
What are you saying here, the common pump is producing 210 Bar regardless of total flow? Just how is this regulated?
Edis
Edis
59
xpensive wrote:What are you saying here, the common pump is producing 210 Bar regardless of total flow? Just how is this regulated?
Yes, the hydraulic system maintains a constant oilpressure of about 210 bar. This pressure is maintained by a variable displacement axial piston pump (swash plate pump) by controlling the hanger angle.
The pump also have the assistance of a hydraulic accumulator which can help supply oil when the oil pump alone can't do it.
Of course, the 210 bar pressure is availible only to the servovalves, then there is a pressure drop over these to the actuators.
The oil return is also pressurised, unlike most hydraulic systems which use an unpressurised return to a ventilated oil tank. This keeps the oil volume in the system small and prevents 'foaming' of the oil which otherwise would cause problem (as it did with Lotus electrohydraulic active ride back in the days).
Ferrari at least used to use an AP05V pump, which is a 2.5 cc variable displacement swash plate pump from Parker Hannifins aerospace division.
http://www.parker.com/literature/Hydrau ... nPumps.pdf
mycadcae
I think the new X-Trac in the industry for F1, right?
Regard,
pgj
pgj
marcush. wrote:Quick sumup of Hydraulic actuation in f1 by moog:
April 13, 2006
Kenneth J. Korane
I have been trying find an answer to a similar question at Williams. We experienced hydraulic problems at the first test. Sam Michael said that we had produced a work around but a fix was some way off. After the first two races Rubens complained of slow gear-shifting. It would be very interesting to know if the problems being experienced by Lotus and Williams are related.
Williams and proud of it.
autogyro
autogyro
I understand that McLaren also had slow and missed shifting but only when not under load. Without access to all the data and the current designs it is almost impossible to guess a common fault. It may have something to do with the latest attempts to increase shift speeds and the alterations to the spool and selector mechanism to achieve this, or it might be the electronics or hydraulics.
I have noted over the years that improvements to increase gear changes for performance use can often reduce the reliability of operation during unloaded (coasting)use.
You say there was a work around.
Can you tell us in what technical area?
Or was it driven around.
pgj
pgj
I don't know what the solution was although it did take the best part of half a day to effect it. I was quoting Sam when asked about the problem. It caused intermittent problems at the first couple of tests. As you say without inside information there is no way that we can know what is going on. Sam then did lots of talking about optimisation of the car's systems. So far there is no evidence of any improvement.
Does Lotus have a different supplier to all the Big teams?
sticky667
sticky667
all of the new boys are using x-trac. the big teams have their own.
scarbs
scarbs
393
I don't believe the hydraulic system comes with either the Xtrac gearbox or the Cosworth engine, this leaves the new teams to design their own hydraulic systems (Pumps accumulators, valve blocks, actuators etc). Lotus problem was the steering rack which again is a teams designed part.
xpensive
xpensive
214
If I can follow you right here edid, the common pump is running with the speeed of the engine, while pressure is controlled by regulating the positive displacement of said pump. What kind of displacement/flows are we talking anyway?
autogyro
autogyro
I do not believe the problem is in the hydrolic system.
I think it is in the design of the selector mechanism, possibly the spools that rotate and move the selector forks.
The problems with hydrolics and electronics are a symptom rather than the cause.
Probably wrong though.
conni
conni
Xtract supplied lotus,virgin & hrt with a bad hydrolic package i hope they kept the reciepts so they can get there money back as under the sale of goods act they could claim its not fit for purpose
conni
