Hello all,
This is my first time posting on this website so if I've posted this in the wrong section, I apologize. I am posting with regard my final year project of a Mechanical Engineering Degree in Ireland. I have chosen to do my thesis on the effect of blown air on a rear wing, as used by Mclaren on their track car.
I plan on doing some F.E.A. testing using a programme called "Ansys", and then make a model for wind tunnel testing. Although I dont know the exact way I'm going to make the wing yet, I think i might use an aluminium skeleton but as regards covering the frame, i am lost. I am thinking fiberglass, but I am not sure yet.
I plan on wind tunnel testing the wing with and without the blowing apparatus. The main problem I have encountered is the blowing apparatus itself. My idea is to have a small airpump outside the windtunnel, then using a small tube to blow air onto the wing. This hopefully should divert the adhesive air stream off the steep edge of the second plane, thus decreasing the downforce.
The thesis itself is in early stages yet, but I thought I would post it on this forum so I could get some useful advice.
Also, I have researched on different explanations of how the 'f-duct' works, most seem to be using the term 'wing stall'. To my understanding of aerodynamics, would a wing stall not create great amounts of wake turbulence or drag?
Thanks in advance for any replies I recieve.
Best Regards,
Patrick
