Red Bull RB7 Renault
ESPImperium
ESPImperium
64
Re: Red Bull RB7 Renault
That ass is so skinny.
Looks as if the RB6 has sliped into some really tight shapewear that a woman would wear. The sharkfin it pretty much what Scarabs said it could be on his blog.
bjpower
bjpower
-1
so when are they releasing the rest of the car :)
Formula None
Formula None
The pullrods are tiny.
Least restrictive rear again this year?
LoudHoward
LoudHoward
Anyone have any thoughts about the black triangular panels on the upper-back of the sidepods? Between the T of the Renault and the R of the Red Bull?
raymondu999
I thought that wasthere on the rb5 and 6 as well
失败者找理由,成功者找方法
creedbratton
creedbratton
LoudHoward wrote:Anyone have any thoughts about the black triangular panels on the upper-back of the sidepods? Between the T of the Renault and the R of the Red Bull?
I'm gonna guess that they are for cooling, depending on where they just replace with gills
mike
mike
looks like exhaust outlet to me, maybe they will test EBD vs non EBD
Formula None
Formula None
That part of the bodywork is in close proximity to the header bundle, so it might just be a more heat resistant paint or material in that area, similar to what Toyota had to do to the TF109 to prevent the paint from discoloring.
RB6 headers relative to exhaust opening:
TF109 w/ local black bodywork:
manchild
manchild
That looks strange to me too, having in mind that exhaust is clearly located on surface of the floor. Why the "patches" unless manifold is bent extremely close to the engine cover, so they couldn't use paint in that zone but had to go for heat-resistant cover or material on both sides.
mx_tifoso
mx_tifoso
I agree with Creedbratton that it's for swapping in the gills when it gets hotter.
myurr
myurr
mx_tifosi wrote:I agree with Creedbratton that it's for swapping in the gills when it gets hotter.
But it doesn't look like there's any screws holding it in place... My vote is for the exhaust being very close to the bodywork in that place before bending down to the floor.
i70q7m7ghw
i70q7m7ghw
49
LOL, this looks exactly like the scarb's drawing from last year, I wouldn't put any bets on Red Bull this year.
vinuneuro
vinuneuro
The rear packaging is amazing. Looking at the engine cover compared to other cars makes me wonder if they compromised CoG to achieve it.
creedbratton
creedbratton
If the exhaust is running close to the bodywork there, then what would be the point of putting in insulation? Better just to let the hot air out so it doesn't overheat anything further down.
Raptor22
Raptor22
26
This is the first car to loose the pullrod completely. So either they are actuating the damper via one to the suspension arms directly or they have built the spring into the carbon fibre wishbones.
Either way, its very trick
