Chassis
Engine
DDD
F Duct
Slicks or Grooves
Front End
Rear End
Would you have the Winglets and addon wings on the sidepods?
Just curious what you could come up with
And that is why certain technology gets banned. If some of it wasn't banned the cars would be too fast and unsafe for humans to be piloting them.Tim.Wright wrote:Basically if you have everything which was banned in the last 10 years you will have a fast car.
If you have everything which was banned in the last 20 years you will have a faster car.
See where I'm going?
Its a pretty pointless discussion if you ask me.
If you build a car to the rules in 1950 rules you could have a quad turbo v16 if you wanted with every aeroydynamic aid imaginable. Of course this would be the fastest F1 car. Question answered.
Tim
Here's why in part active ride height was banned. When it failed, this happened.Byronrhys wrote:^ Thats all true, but the FIA do ban some things on occasions where we see no reason, ie. the Active ride height, Mass damper and the DDD (IMO).
That is why I use the 2010 front wing..it is the widest body part of the car.marcush. wrote:you are assuming that all components would give a net benefit when combined...wich is not necessarily true.
example: an outwash endplate does not make much sense with a front wing not the widest part of the car .before the wide wing was specified the endplates design was to duct air between the front tyres.
This was, is, and always will be a bullshit copout reason for banning anything, especially active ride.Giblet wrote: Here's why in part active ride height was banned. When it failed, this happened
When the system fails, and since mild hydraulic systems often fail in even modern day F1, it could be catastrophic.
