Sorry to be totally off the wall, but some thoughts have occurred to me of late about the current regs and quite where the boundaries are. Perhaps some of the esteemed members can advise?
I understand that the retarded ignition concept works when off throttle by timing the spark such that the combustion takes place as the fuel-air mix is being pushed out of the cylinder. One of the problems with this is that an amount of unburnt fuel-air is finding it's way into the exhaust system, but the benefit is that the amount of gas coming out of the end of the pipe is more regular while off throttle allowing the exhaust gas to be used to augment downforce giving devices such as the blown diffusor (please correct me if I am wrong!).
Well, it occurred to me, given the current development work going on with Renault's Forward Exhaust Exit, but more generally the idea of using exhaust gases for gain, if a suitably motivated team could find a way to actually use any unburnt fuel finding it's way into the pipe and allow it to combust there.
The title of this thread is perhaps misleading, but AFAIK, the Pulse Jet employed on the V1 bomb during WW2 consisted larely of a large bore pipe which had a combustion chamber in it's middle, and two "exhaust" pipes leading out of each end of it, with one pipe bent around to vent in the same direction as the other.
Well, what if, in an attempt to increase mass flow, perhaps only while off-throttle, a team were to design a system where lots of unburnt fuel/air was being pumped into a combustion chamber, and that combustion chamber was cleverly arranged so as to allow combustion, but the products of that combustion were vented outwards through two additional outlet pipes? A suitable glow-plug could theoretically be used to ignite any unburnt fuel arriving in the chamber, and in theory, this could produce significantly more mass flow at the crucial moments.
The technology required to acheive such a device is not "rocket science" (pardon the pun!), as it was successfully achieved on Scrapheap challenge using only bits of junk:
[youtube]http://www.youtube.com/watch?v=8QoP4zX8Gwc[/youtube]
I know it sounds off the wall, and I doubt very much if anyone would be mad enough to actually try it, but I don't know of any specific regulations which would explicitly prohibit it.
Just a stupid idea off the top of my head so don't flame me!
