Just wondering the number of times Webber has flipped a car.. Paranormal?
- 1999 24 Hours of Le Mans(Twice)
- European Grand Prix 2010
My thoughts exactly. He's just trying to feel more at home.The FOZ wrote:Nah, not paranormal. He's an Aussie, they're upside down to the rest of us. It's just his true nature asserting itself.
I'm really not convinced that this was down to plonkeritis. I'm pretty sure that both this, and Vettel's crash with Button at Spa were caused by the same thing – red bull's flexi wing.andrew wrote:From memory, I don't think his Le Mans flip was his fault, but the flipperoo in Valencia was due to him comming down with a case of plonkeritus.
LOL, best explanation so far =D>The FOZ wrote:Nah, not paranormal. He's an Aussie, they're upside down to the rest of us. It's just his true nature asserting itself.
That's some wind tunnel you got there, expect teams to be knocking at your door any minutebeelsebob wrote:
[*]The car starts running in thin air in the {lotus | McLaren}'s slip stream.
[*]The driver steers to the right to make the pass
[*]The right hand end of the front wing comes into the higher preasure zone and immediately starts to work much harder.
[*]The right hand end flexes as it generates more downforce, causing the whole wing to tilt slightly down on the right.
[*]The wing being tilted generates a component of it's downforce to the left.
[*]This extra force on the front of the car pushes the nose back in behind the car being overtaken
[*]We know the rest
Yes it's applied in the center, but you have to consider where that force is being exerted, remember there's a distance from where the force is applied to the nose, so torque comes into play. Downforce that's laterally uneven will also cause grip that's laterally uneven. Not that this would help make sense of Beelsebob's explanation, but I thought it should be mentioned.Giblet wrote:the downforce is all applied to the nose in the center, so the it wasn't unevenly loaded, just varying in amount.
The wings were flapping back and forth when he tried to pass Button that time, but also, the downforce is all applied to the nose in the center, so the it wasn't unevenly loaded, just varying in amount.
