Spanish GP 2011 - Barcelona
andrew
andrew
Location: Aberdeen, Scotland - WhiteBlue Country (not the region)
Circuit information
Length: 4.655km
Race distance: 66 laps / 305.256km
Full throttle: 57%
Top speed: 308kph
Longest flat-out section: 16s / 1.14km
Right/left-hand turns: 9/7
Tyre wear: Medium
Brake wear: high
Downforce level: High
Gear changes per lap: 44
Tyres
2010 tyre compounds: hard (prime, no markings), soft (option, green markings)
2009 tyre compounds: hard (prime, no markings), soft (option, green markings)
2008 tyre compounds: hard (prime, no markings), medium (option, white markings)
Average fuel consumption: 2.271kg per lap (source: Williams)
Pit lane time loss: 22 seconds
2010 Result
Re: Spanish GP 2011 - Barcelona
You are getting pretty good at this aren't you? :lol:
Not driving a Mercedes? Work harder!
HampusA
Seems like RBR will again dominate the Q here. Wonder if Webber gained anytime here aswell last year? ;)
The truth will come out...
ajdavison2
ajdavison2
32
Off topic but is that not technically cutting the corner ( four wheels outside of the white line)?
MrBlacky
MrBlacky
Curb = track. At least two wheels on track.
ajdavison2
ajdavison2
32
ahh right I was never fully clear on the rule haha
beelsebob
beelsebob
179
MrBlacky wrote:Curb = track. At least two wheels on track.
Incorrect.
20.3 Drivers must use the track at all times. For the avoidance of doubt the white lines defining the track edges are considered to be part of the track but the kerbs are not.
n smikle wrote:You are getting pretty good at this aren't you? :lol:
I'm guessing he has the whole season set up already and as the cars cross the line for one race he's then able to post the next one quick sharp. I'd be impressed if I didn't think it was ever so slightly sad... :wink: :lol:
Turbo says "Dumpster sounds so much more classy. It's the diamond of the cesspools." oh, and "The Dutch fans are drunk. Maybe"
ajdavison2 wrote:Off topic but is that not technically cutting the corner ( four wheels outside of the white line)?
Yes, it's cutting the corner and is a "naughty". So long as all of them do it at that point then the stewards won't worry too much at a guess.
ajdavison2
ajdavison2
32
Like the pit lane entry at Interlagos then?
raymondu999
150
Having said that though, that turn is one of those that the teams kind of "agree" is a nothing to cut. All 24 cut that corner in a similar fashion last year. From the Red Bulls to the HRTs.
失败者找理由,成功者找方法
HampusA
Bit extreme though when your not even on the curb ;)
MrBlacky
MrBlacky
Incorrect.
Mh okay. But I'm quite sure that he wasn't the only one who cut the track there.
andrew
andrew
Nearly perfected the technique! :lol:
Just_a_fan wrote:I'm guessing he has the whole season set up already and as the cars cross the line for one race he's then able to post the next one quick sharp. I'd be impressed if I didn't think it was ever so slightly sad... :wink: :lol:
I don't have anything set up previously. It only takes a couple minutes to find a reliable source for the info.
If you don't like it don't post in it then! :wink:
Gerhard Berger
Gerhard Berger
RB will probably dominate, but Webber was better than Vettel at this circuit for the last 2 years, so will be interesting to see how that one pans out...
