etusch
131
Rodak wrote:
30 Jun 2026, 02:48
etusch wrote:
29 Jun 2026, 13:31
FIA, or whoever makes the engine regulations, is restricting some things in a nonsensical way. Anyway, if it's going to be a MGU-K with transmission, it would be much more effective to use CVT for it, separate from the ICE's power transfer system.
I hope they never do allow CVT transmissions, the steady drone of the engines always running at optimum rpm would be..... annoying.
Not for transferring engine power to the ground. It would be a continuous, constantly adjustable coupling to activate the MGU-K during braking. Trail braking would even be possible.
gansaraku
gansaraku
Hello everyone, it's been a while since I posted anything.
In some Spanish media, there is talk of an improvement in the power gain of the Honda engine this season that could be around 70hp, depending on the revolutions and the delivery.
This contradicts the ADUO a bit, so, since we were a bit stuck, let's share some info?
PS:In Hungaroring, some journalists were also going in this direction, maybe not so optimistic, but we were talking about a gain frame between 20/50hp
see you guys
gansaraku wrote:
26 Jul 2026, 15:25
see you guys
They have no clue, wait for it to be released.
mzso
mzso
75
ispano6 wrote:
29 Jun 2026, 17:54
mzso wrote:
16 Jun 2026, 23:19
DDopey wrote:
16 Jun 2026, 15:10
I would not trust a purely LLM generated text without context. However, when using LLM’s in combination with the right context (and it can give references as proof), it can provide additional insights and relations between different data. With the recent improvements in reasoning and combining it with agentic where it can search for additional context itself, I would not dismiss it that easy.
He fed it his own bias, and articles with rumors and guesses that supported his bias. And the AI hallucinated a reinforcement.
None of what I fed it I wrote. I only provide sources. Though I'm not surprised by your response. You're the type that if no one else is talking about it, it must not be a thing. In my line of work, which is wrapping my head around an engineering problem and then trying to understand the root cause, you tend to look at places or ask questions people failed to ask or consider. We use AI to cut through the menial sifting of code, analysis of data, and sources of truth. You see, what you failed to understand is that I have no bias other than to point out your guys bias and that the incompetence you so love to call Honda is misplaced.
Now you make up stories and say I feed it biases. Clearly you don't know how to intelligently use notebookLM and you assume the level I use AI is at the same as yours. Probably a big difference.
(I've been on a "vacation" so this is a tad belated.)
Wow. Saying "I have no bias other than to point out your guys bias" has to be some of the most biased things anyone can ever write.
Not only that, your bias is incredibly huge and obvious. You're quick to throw anyone and anything under the bus to shift away blame from Honda. Whether it has and basis or sense does not seem to matter
Whether it's Newey designing a "bendy chassis", or it's "all the suspension's fault', or it's "the gearbox", or lately the "Honda is lacking in power because of Aramco", or just accusing Newey of lying.
You said you provided sources to the AI, but you provided none here for the purported fuel issue. You just insulted people, by telling them to ask the AI.
Everyone should take with a good amount of doubt what you claim when it concerns Honda or anything related to Japan. As long as you don't provide a hard source.
maguetox
maguetox
diffuser wrote:
26 Jul 2026, 17:30
gansaraku wrote:
26 Jul 2026, 15:25
see you guys
Is there a realistic clue of the potential improvements of the next PU?
maguetox wrote:
27 Jul 2026, 19:26
diffuser wrote:
26 Jul 2026, 17:30
gansaraku wrote:
26 Jul 2026, 15:25
see you guys
I would say that since this is the last one for the year, they've put everything they've learned into it and don't expect to have any more improvements before March of 2027. I also think it means they've found some worth while improvements for real numbers, otherwise they wouldn't have done it. I have no idea how big it is nor would I believe anyone that says they know..
maguetox
maguetox
diffuser wrote:
27 Jul 2026, 20:06
maguetox wrote:
27 Jul 2026, 19:26
diffuser wrote:
26 Jul 2026, 17:30
"I'm expecting a noticeable improvement, but my main concern is whether ARAMCO’s fuel quality is truly on par with the rest of the grid. Considering all the issues this program has gone through, it feels like the ARAMCO–Honda relationship hasn’t been as strong or as seamless as the ExxonMobil partnership from the previous era."
maguetox wrote:
27 Jul 2026, 21:25
diffuser wrote:
27 Jul 2026, 20:06
maguetox wrote:
27 Jul 2026, 19:26
Aramco probably have the most experience with the fuel, since they've been making it for F2 for a couple of years. Nobody else has had that kind of experience and feed back. It's no guarantee that it is the best but they should be in the ballpark. This fuel change is new for 2026 for everyone. So whatever Honda was using with ExxonMobil in the past, is full not usable this year.
