2026 Aston Martin Aramco Formula One Team
zoroastar
Re: 2026 Aston Martin Aramco Formula One Team
id like to see an overhead layout of the pitlane along with the paths the penalized drivers took compared with others that didnt. like, if drivers didnt cross over any illegal boundaries, and never literally broke the actual speed limit, it seems like BS to get a penalty.
if penalties are gonna start being handed out during races for invisible discrepancies... well it goes perfectly with the way these engine rules have gone so far
zoroastar wrote:
10 Jun 2026, 02:12
https://www.motorsport.com/f1/news/expl ... /10828092/
"The FIA has found no irregularities in its measurement system and believes the wave of penalties is linked to drivers slightly cutting the pitlane entry. Teams were warned about this by race control before the start."
They were warned.
etusch
131
hollus
diffuser wrote:
10 Jun 2026, 14:13
zoroastar wrote:
10 Jun 2026, 02:12
They were warned.
They measure the time between 2 points. The shortest line between 2 points is a straight, and they argue that the drivers took a shorter line. It would follow that the “standard” FIA path is not a straight line, or not the shortest possible straight line. Not exactly bulletproof.
¡Puxa Sporting!
NAPI10
NAPI10
I wont belive such rumors even if it's confirmed by Newey.AM has faulted too many times.
TyreSlip
TyreSlip
NAPI10 wrote:
10 Jun 2026, 15:21
I refuse to believe the 2 seconds rumour too until the team can prove otherwise. But it is imperative that this update is completed before Hungary because they cannot wait until the end of August to decide on car direction for next year.
mzso
mzso
75
diffuser wrote:
09 Jun 2026, 20:35
mzso wrote:
09 Jun 2026, 13:50
diffuser wrote:
09 Jun 2026, 12:24
The truth is, the regs have been like that for decades. Gas has raced there several times. He knew the regs. Tried to get an advantage, miscalculated or forgot. Then got caught.
Nothing to do with the regs. By the regs he wasn't speeding at all, probably none of them were.
The measurement is defective.
Why didn't Gasly get a penalty for speeding in the pitlane over the previous 8 years he's raced at Monaco? The rule didn't change, the way they measure it didn't change...His approach this year did change though. Between FPs, Qualifying and the race, he must use the pitlane limiter 20 times a year @ Monaco.....If a guy has done something 20 times a year for 8 years and never gotten it wrong now gets it wrong only during the race twice ...something he's doing changed.
You can say what you want about how it's measured but he knew the rule going in and has known it for now 9 years! He better learn it cause it will be the same next year.
As I said it has nothing to do with the rules! Nor with Gasly doing anything wrong.
He abided by the rules and still got penalized.
"something he's doing changed."
- or not. More likely the FIA set up the speed measurement even crappier than usual. Or the extra pits exposed its inadequacy more.
mzso
mzso
75
diffuser wrote:
10 Jun 2026, 14:13
zoroastar wrote:
10 Jun 2026, 02:12
They were warned.
Irrelevant. It's not the driver's responsibility to work around the useless FIA measurement system. It's the FIA's responsibility to measure the speed right and not punish drivers who weren't speeding.They reined Russel's race and Gasly's as well.
mzso
mzso
75
TyreSlip wrote:
10 Jun 2026, 15:37
NAPI10 wrote:
10 Jun 2026, 15:21
With their position it's entirely possible. Especially if they roll out a new car and engine upgrade.
HPD
198
Fernando Alonso on the AMR26:
"In Australia, we found our engine was down.
"In China, we found our energy was down.
"In Monaco, we found our chassis is bad.
"In Miami, we found our gearbox is very bad."
I want to add that the seat is bad too hahaha
ScottB
ScottB
mzso wrote:
10 Jun 2026, 16:35
TyreSlip wrote:
10 Jun 2026, 15:37
NAPI10 wrote:
10 Jun 2026, 15:21
And a new gearbox, from the looks of it...
Rikrikrik
Rikrikrik
I'll only believe it when I see it. Their recent history with updates has never been in their favor; on the contrary, I'd venture to say it could get even worse than it is now. Yes, I believe it could still get worse.
mzso wrote:
10 Jun 2026, 16:28
diffuser wrote:
09 Jun 2026, 20:35
mzso wrote:
09 Jun 2026, 13:50
ok, so what is the rule?
Is it that you can't go faster than 60KPH in the pitlane? or is it ? in the pit lane you can't go from point A to point B in less than X time ?
The way I understand it...it is...That you can't go faster than 60KPH in the pitlane as measure from point A to point B in less than X time.
Rikrikrik wrote:
10 Jun 2026, 17:38
What difference would it make it we believed it before we saw it ?
mzso
mzso
75
Rikrikrik wrote:
10 Jun 2026, 17:38
They didn't have any updates. Honda implemented something to reduce vibrations, but that's not a PU update, and probably has a weight penalty. Also it was said that the engine cannot be run at full power until the mounting is redesigned, so there is a lot to gain. Of course it's entirely possible to mess things up again, but less likely.
