Chicane Lane...
slinger
Chicane Lane...
Hi All
Curved questions to all you Racing enthusiasts :D .
Seeing as there is no lane changing allowed in the braking zone, would it not be interesting to put a pit lane exit type of no cross white line down the center of the road through a chicane and once you have picked you line into the braking zone you have to stick to your lane through the corner?
How would the 2 differing lines/lanes be advantaged or disadvantaged through the chicane as to the one being able to brake a bit later and the other being able to maybe get on the gas a little earlier?
Cheers... :wink:
Overtake you must, if not loose you will...
KeiKo403
KeiKo403
Re: Chicane Lane...
I think this is a solution for a problem which doesn't exist in all honesty. Maybe others will see merit in the idea but I don't sorry.
Some thoughts I have on it though are:
  • In a simple 2 car battle with plenty of room on the track this would be easy, but it would be very Scalextric and not very sporting.
  • what if there is more than 2 cars? (also what about lap 1 with all cars?)
  • Is it safe to paint white lines in braking/turning/acceleration zones if the track is wet?
  • In narrower tracks like Monaco, I doubt this could even be implemented
  • Do cars have freedom of full track width if not in battle with another car?
  • what defines 'in battle with another car'?
  • what if Turn 1/2 Monza (For the Max/Lewis crash) both drivers choose the same part of the track, that forces single file as the track width is cut in half
  • How far back from the chicane does the 'pick your lane' start?
I'm not expecting you have answers to these, they would just be my concerns/considerations.
SiLo
130
Re: Chicane Lane...
I think a better rule should be to stop drivers moving late at all, moving late is what causes crashes.
Felipe Baby!
Hoffman900
Hoffman900
164
Re: Chicane Lane...
I think the risk of crashing and DNF’ing is enough, but I might be a bit old school.
adrianjordan
Re: Chicane Lane...
Hoffman900 wrote: ↑
14 Sep 2021, 17:42
Don't talk common sense!! 😝
Favourite team: McLaren
Turned down the chance to meet Vettel at Silverstone in 2007. He was a test driver at the time and I didn't think it was worth queuing!! πŸ€¦πŸ»β€β™‚οΈ
Stu
Re: Chicane Lane...
slinger wrote: ↑
13 Sep 2021, 16:36
Hi All
Cheers... :wink:
I was thinking of something a little different to that, what if there were no chicanes at all. Monza would be absolutely mental!
NL_Fer
NL_Fer
82
Re: Chicane Lane...
Maybe the 2022 cars would allow for closer following and the are side by side earlier on the straight, with lesser speed difference.
Nowadays, they come together at the braking zone, with 20-30kph speed difference and sudden overtaking.
Big Tea
Re: Chicane Lane...
Stu wrote: ↑
14 Sep 2021, 19:15
slinger wrote: ↑
13 Sep 2021, 16:36
Hi All
Cheers... :wink:
They would not get the battery charged would they ?
JordanMugen
82
Re: Chicane Lane...
slinger wrote: ↑
13 Sep 2021, 16:36
:wtf: :lol:
slinger wrote: ↑
13 Sep 2021, 16:36
Cheers... :wink:
I see the emoticon there! Putting lanes on the track in motor racing -- be it the chicane or around the whole track -- would be bizarre in the extreme IMO.
sosic2121
sosic2121
Re: Chicane Lane...
Stu wrote: ↑
14 Sep 2021, 19:15
slinger wrote: ↑
13 Sep 2021, 16:36
Hi All
Cheers... :wink:
Yes!
Chicane is a lazy solution for "track being too fast and too dangerous".
Re: Chicane Lane...
slinger wrote: ↑
13 Sep 2021, 16:36
Hi All
Cheers... :wink:
It is a good Idea because chicanes ten to be low speed areas so feeding in from the Pits would be safer in theory.
The disadvantage to this is that chicanes are usually placed at points between alternate configurations. Meaning you have a high speed straight in configuration 1, but if it is too dangerous for one racing category you stick a chicane in the middle of it and call that configuration 2. Because of this the Pitlate exit line must be in a position to service the two configuations. If you run the pit lane exit line through the chicane in Config 1, it will add immensly to the pitstop time.
So in summary running pitlane exit through a chicane is OK for safety since its a slow speed area, but it can add much to the pitlane time loss depending on track configuations.
flmkane
flmkane
Re: Chicane Lane...
sosic2121 wrote: ↑
17 Sep 2021, 09:11
Stu wrote: ↑
14 Sep 2021, 19:15
slinger wrote: ↑
13 Sep 2021, 16:36
Hi All
Cheers... :wink:
Yes!
Hmm.... Monza with no chicanes
Top on my fantasy bucketlist tracks
Henne
Re: Chicane Lane...
slinger wrote: ↑
13 Sep 2021, 16:36
Hi All
Cheers... :wink:
We just can't put everything in little rules. It just wouldn't work. Just let them race is what I would say. Too many rules or fingerpointing by race control at the moment.
