Mercedes W12
dans79
267
Re: Mercedes W12
Owen.C93 wrote:
19 Nov 2021, 19:49
I didn't say it wasn't allowed. I'm just showing the gap when stood still and when at speed to try and figure out what RBR are referring to.
we are getting more into a topic area that should be in the team thread vs the car thread. but if you are talking about The tami tweet saying the main plane flexes down, I personally think that's tin foil hat territory. If you want to stall the rear wing, you want the slot to narrow, not open. Teams did exactly this in 05/06, and is why slot gap separators were introduced.
202 105 104 9 9 7
holeindalip
holeindalip
Re: Mercedes W12
I’m just not seeing it in the pics provided. I don’t see how the main plane can bend/flex when a screw goes through the end plate and attaches right where the supposed scuffs/score marks. If the screws weren’t there then it would fail the 85mm slot gap 10n test which is what happened. The screws came loose…
RZS10
359
Re: Mercedes W12
Would something like this even be feasible from a carbon/material standpoint?
dans79
267
Re: Mercedes W12
RZS10 wrote:
19 Nov 2021, 21:56
https://i.imgur.com/mVFwkFC.gif
No, not unless you had 2 discrete layups with some kind of flexible hinging element bridging them!
202 105 104 9 9 7
JordanMugen
90
Re: Mercedes W12
dans79 wrote:
19 Nov 2021, 22:02
RZS10 wrote:
19 Nov 2021, 21:56
If it is designed to do that, that is certainly a moveable aerodynamic device.
Anyway Newey may as well lodge the protest and see if there is anything in the theory or not, he has been around racecars long enough to know what you might want to do or not want to do. :)
dans79
267
Re: Mercedes W12
JordanMugen wrote:
19 Nov 2021, 22:03
dans79 wrote:
19 Nov 2021, 22:02
RZS10 wrote:
19 Nov 2021, 21:56
Of course, but it would be so blatantly obvious, anyone who knows anything about composites would be able to see it from a mile way!
202 105 104 9 9 7
siskue2005
siskue2005
70
Re: Mercedes W12
RZS10 wrote:
19 Nov 2021, 21:56
I don't think it will possible to make some thing in carbon fibre to bend like that AND pass the new FIA load test.
Why haven't redbull protested yet if that's the case. I say they are just throwing everything on the wall and hoping some to stick.
Initially they were questioning plenum sensor placement and then suspension and now the rear wing.
Redbull are just trying to destabilise or hoping to destabilise merc
TimW
TimW
36
Re: Mercedes W12
Owen.C93 wrote:
19 Nov 2021, 19:49
Here's 2 decently similar angles from high speed and stood still. Need to find something a bit sharper and a higher speed though.
https://i.imgur.com/xMV2mvR.png
https://i.imgur.com/cBNxw4h.png
The amount of daylight is very similar in both photos.
siskue2005 wrote:
19 Nov 2021, 22:11
The FIA load test does not load the lower element, so local flexibility here would not be detected.
siskue2005
siskue2005
70
Re: Mercedes W12
TimW wrote:
19 Nov 2021, 22:19
siskue2005 wrote:
19 Nov 2021, 22:11
Then which part do they test? The upper DRS flap can't be tested as it's a movable part. Honestly I am confused. Any source or fia test analysis will be helpful
TimW
TimW
36
Re: Mercedes W12
siskue2005 wrote:
19 Nov 2021, 22:22
TimW wrote:
19 Nov 2021, 22:19
siskue2005 wrote:
19 Nov 2021, 22:11
As far as I know the load is still applied through the end plates.
https://www.motorsport.com/f1/news/f1-b ... 29890/amp/
siskue2005
siskue2005
70
Re: Mercedes W12
TimW wrote:
19 Nov 2021, 22:39
siskue2005 wrote:
19 Nov 2021, 22:22
TimW wrote:
19 Nov 2021, 22:19
They do pull back the flaps. Picture from above link
Sieper
73
Re: Mercedes W12
Indeed, they test the whole wing, as a unit. There are limits in that, redbull was passing these earlier in the season but it was still deemed (as you could see the whole unit move down on the rear facing camera) moveable aero. And it did indeed move. So the testlimits were made more strict and the camera reference stickers got introduced.
Now the main plane. It’s supposed to be secured. There are no tests nor limits. It cant be moving independently.
siskue2005
siskue2005
70
Re: Mercedes W12
Sieper wrote:
19 Nov 2021, 23:06
Could u give a source or link for that.
I couldn't find anything anywhere
Thank you
Sieper
73
Re: Mercedes W12
siskue2005 wrote:
19 Nov 2021, 23:14
Sieper wrote:
19 Nov 2021, 23:06
Thank you
What do you mean? The whole wing is supposed to be a rigid unit, you can’t have moveable aero. If the mainplane bends like the scratches and the images of the car under speed seem to show, than that is movable aero. There is no limit or margin for that.
Do you dispute the wing should be a solid unit (excluding the DRS flap movement allowance) or have I misunderstood?
TimW
TimW
36
Re: Mercedes W12
siskue2005 wrote:
19 Nov 2021, 22:44
TimW wrote:
19 Nov 2021, 22:39
siskue2005 wrote:
19 Nov 2021, 22:22
https://cdn-3.motorsport.com/images/mgl ... test-1.jpg
Hmm, seems to me that the load is introduced through the frame(yellow) that is clamped around the end plates. But I now see the are also yellow elements on the upper flap. Nothing on the lower flap though.
Edit: the first image in the article only shows the frame clamped to the end plates. The text refers to the end plates, but is not unambiguous.
