Red Bull RB18
Re: Red Bull RB18
Isn't that just where the tethers run through?
timbo
timbo
113
Re: Red Bull RB18
Oh, I forgot, thanks. So what was the verdict then? Was it used as a spring/ARB combo?
Re: Red Bull RB18
timbo wrote:
24 Feb 2022, 23:13
So the top forward suspension arms are actually a single continuous element? Can it be used as a spring itself?
And if true, what's that first semi-dependent front suspension of an F1 one car in like, ever?
Red Bull applied this treatment to the front lower control arm last season.
#ReleasetheADUO
humble sabot
27
Re: Red Bull RB18
Anyone else get strong 919 vibes from these sidepods?
the four immutable forces:
static balance
dynamic balance
static imbalance
dynamic imbalance
Hoffman900
Hoffman900
242
Re: Red Bull RB18
humble sabot wrote:
25 Feb 2022, 03:26
I was thinking Lola T332
240
Re: Red Bull RB18
That lower panel is kevlar as mentioned before for debris impact, or it's heat resistant material.
jagunx51
185
Re: Red Bull RB18
ojir19 wrote:
23 Feb 2022, 13:34
they removed the sensor, but what are those "3 dots" ? .... I dont think those are holes
https://i.postimg.cc/rp6jyNCv/rb18-2022 ... 183444.jpg
what is that ? :?:
Re: Red Bull RB18
jagunx51 wrote:
25 Feb 2022, 06:03
ojir19 wrote:
23 Feb 2022, 13:34
what is that ? :?:
You're over thinking it. Just some holes that have been plugged.
#ReleasetheADUO
DAMNINice
37
Re: Red Bull RB18
25 Feb 2022, 09:43
Someone from AMuS photographed the Redbull shock absorber with which you can adjust the distance
between the floor and the asphalt.
Increments and decreases with millimeter tolerance.
https://pbs.twimg.com/media/FMYWs2HXIAc ... name=small
Is this standard on all the cars?
Or do they have a nice trick here to couteract porpoising by "damping" the floor movement?
REal men play with twins!
timbo
timbo
113
Re: Red Bull RB18
DAMNINice wrote:
25 Feb 2022, 09:47
That should be illegal. Ferrari used a floor suspended on the dampers in 2006 and it was duly banned in 2007.
FW17
184
Re: Red Bull RB18
25 Feb 2022, 09:43
Is that Red Bull or Haas?
AeroDynamic
349
Re: Red Bull RB18
FW17 wrote:
25 Feb 2022, 10:04
25 Feb 2022, 09:43
It's Haas, already posted in the Haas thread.
Looks like the same floor as run previous days so far. Interesting shot of the side pod without the cover.
flowViz on the intricate part of the floor
Re: Red Bull RB18
FW17 wrote:
25 Feb 2022, 10:04
25 Feb 2022, 09:43
It is from Haas. The Twitter message wasn't correct. I edited it.
Bandit1216
21
Re: Red Bull RB18
AeroDynamic wrote:
24 Feb 2022, 22:38
Internal packaging peek of the Honda engine in 22
https://pbs.twimg.com/media/FMYP8urXsAs ... name=large
One piece wishbone from left to right
But just suppose it weren't hypothetical.
Re: Red Bull RB18
It's the HAAS, and it's nothing to do with altering the floor/ride height distance, it's there to set preload on the splitter to pass the FIA flex tests while still allowing it to move.
Very surprised the FIA are letting them using a damper there since the introduction of the test and moving away from the carbon stays though. Nothing to stop you using massive rebound damping to almost permenantely deflect the splitter.
