Red Bull RB18
AeroDynamic
349
Re: Red Bull RB18
Henk_v
Henk_v
89
Re: Red Bull RB18
AeroDynamic wrote:
25 Feb 2022, 10:13
FW17 wrote:
25 Feb 2022, 10:04
25 Feb 2022, 09:43
Someone from AMuS photographed the Redbull shock absorber with which you can adjust the distance
between the floor and the asphalt.
Increments and decreases with millimeter tolerance.
https://pbs.twimg.com/media/FMYWs2HXIAc ... name=small
Is that Red Bull or Haas?
It's Haas, already posted in the Haas thread.
Looks like the same floor as run previous days so far. Interesting shot of the side pod without the cover.
https://cdn-1.motorsport.com/images/mgl ... tail-1.jpg
flowViz on the intricate part of the floor
https://cdn-1.motorsport.com/images/mgl ... ng-r-1.jpg
That shot of the naked sidepod more or less debunks anything fishy going on behind the undercut panel.
Also it looks like there is room to have less width in the sidepod, hence the sidepod width seems to be an aerodynamical choice, with options for sleeker variations.
AeroDynamic
349
Re: Red Bull RB18
@NicolasF1i
Rear pushrod suspension and central cooler on the Red Bull RB18.
Albert Fabrega
Detail of the rear Push-rod suspension rocker of the Red Bull.
MercAMGF1Fans
MercAMGF1Fans
Re: Red Bull RB18
tmoneyr007
tmoneyr007
Re: Red Bull RB18
[/quote]
Looks like they have a ridiculous amount of space still available in the undercut region if they want to modify the sidepod shapes further.
Re: Red Bull RB18
MercAMGF1Fans wrote:
25 Feb 2022, 12:47
amazing video as always from this channel. Interesting ideas about the sidepod inlet & beam wing designs
I like the idea of the modularity of the sidepod inlet design. Similar in principle to the supposed idea that RB/Ferrari took with the modular nose
Is the RB double notch floor something that's relatively easy to copy and hence will likely be seen up and down the grid? It seems it would be to me
SiLo
146
Re: Red Bull RB18
25 Feb 2022, 13:23
25 Feb 2022, 12:47
The beam wing is most interesting to me, really the lower element is just there to support the diffuser, and then the top element is protecting the rear wing from the lower element frontal flow.
Felipe Baby!
AeroDynamic
349
Re: Red Bull RB18
Mattchu
65
Re: Red Bull RB18
That`s one thing I`m really going to miss! Seeing the brake discs glow super bright orange and knowing it was pure heat and energy really was a site to behold. Now we`ve got these awful looking wheels/covers that just look daft...
Is that orange stuff to help transfer heat from the disc to the rim or stop it? Looks more of an insulator to me.
Zynerji
112
Re: Red Bull RB18
Mattchu wrote:
25 Feb 2022, 16:30
Looking at it, it almost looks like an evaporative cooling setup might be in that upper plenum as well... When zoomed, it looks like a scotch-brite pad insulating or heat sinking the disc...
This may be a super interesting item for a Scarbs video! Explaining the changes that the wheel philosophy has had on the internals of the wheel tin.
Re: Red Bull RB18
The more I look at this car and the more angles I see, I can't help thinking that the team used the Valkyrie project to good advantage. I just keep seeing vague similarities to elements of that car.
Henk_v
Henk_v
89
Re: Red Bull RB18
Might it be brake dust management? With no airflow through the rim this might become an issue. A clear duct can be seen from the calipers running to the cooling duct, maybe to extract the dus, while the spungelike material retains residual dust ?
AeroDynamic
349
Re: Red Bull RB18
rileykirn
rileykirn
Re: Red Bull RB18
I think the containment & extra insulation around the brakes this year have to do with the fact that the hot air can only exit the back inisde off the wheel, the same side it enters on. How air is blown into the center of the hub, is forced out through the vent holes & channels in the brake rotor & then is captured & exits out the back inside rear of the hub.
