Mercedes W13
SmallSoldier
SmallSoldier
486
Re: Mercedes W13
Mercedes trying to control floor flex:
Vía AlbertFabrega
mkay
mkay
16
Re: Mercedes W13
Is this legal?
Vyssion
Moderator / Writer
Re: Mercedes W13
mantikos wrote:
25 Feb 2022, 17:04
ryaan2904 wrote:
25 Feb 2022, 09:42
kfrantzios wrote:
24 Feb 2022, 19:04
Enough.
Vanja has put together some technical content for a technical forum. Vanja is not Mercedes. Vanja doesn't have Mercedes CAD. To assume that he claims it to be exactly identical in performance is delusional.
The purpose of these sidepod simulations was to provide insight into the "broad overall flow regime" in each of their presence. The reason why he, jjn, and myself recommended against numbers is for this very reason. They are to serve as a delta in order to point out how each team's design "might" be aimed at achieving.
To everyone jumping on the bandwagon here, for one to feel the need to "comment" and point out "wElL yOuR cAd IsNt ExAcTlY tHe SaMe sO wRoNg!!" doesn't make you a technical contributor who feels obligated to issue a warning to all potential viewers of the content; it makes you an obnoxious armchair expert who feels like they need to state the obvious to everyone around you when nobody cares in the first place because we already know.
Back on topic, please. The place to discuss Vanja's CFD is here viewtopic.php?t=30249
"And here you will stay, Gandalf the Grey, and rest from journeys. For I am Saruman the Wise, Saruman the Ring-maker, Saruman of Many Colours!"
#aerosaruman
"No Bubble, no BoP, no Avenging Crusader.... HERE COMES THE INCARNATION"!!"
mantikos
mantikos
35
Re: Mercedes W13
Thank you for sharing these
AeroDynamic
349
Re: Mercedes W13
Can someone translate the Italian? I don't think we can rely on a virtual translator.
The Brake Duct 2022 a new challenge there is no longer the dissipation of heat towards the outside of the wheel, which leads to "sealing" the entire affected area.
Here we can see how #Mercedes on the # W13 built it (highlighted) inlet and outlet ducts # TechF1 # F1
📸 @Alessio_DeMarco
Le Brake Duct 2022 una nuova sfida non c'è più lo smaltimento di calore verso l'esterno ruota, ciò porta a "sigillare" tutta l'area interessata.
Qui possiamo vedere come #Mercedes sulla #W13 l'ha costruita (evidenziati) condotti d'entrata e uscita #TechF1 #F1
📸 @Alessio_DeMarco
inlet and outlet ducts being sealed, the Brake Duct must increase their efficiency in terms of heat dissipation, for this we see a hub body that has no openings (center).
(evidenziati) condotti d'entrata e uscita essendo sigillate le Brake Duct devono aumentare la loro efficienza in termini di smaltimento calore, per questo vediamo un corpo mozzo che non presenta aperture (centro). #TechF1 #F1 📸 @Alessio_DeMarco
ema00
ema00
Re: Mercedes W13
AeroDynamic wrote:
25 Feb 2022, 18:19
https://pbs.twimg.com/media/FMdDCFaXoBI ... name=large
📸 @Alessio_DeMarco
📸 @Alessio_DeMarco
https://pbs.twimg.com/media/FMdFa0VXoAQ ... name=large
I'm italian and it is written in a very bad way, the transaltion is still accurate but has no sense also in the native language (at least to me). The only part missing in the translation is the first bracket that is: (highlited)
Re: Mercedes W13
SmallSoldier wrote:
25 Feb 2022, 17:59
https://i.imgur.com/jsMpVCw.jpg
Vía AlbertFabrega
That looks very "did it last night".
matt_s
matt_s
Re: Mercedes W13
mkay wrote:
25 Feb 2022, 18:11
Is this legal?
Doesn't need to be for testing. They're trying to find out what, if any, impact it has. If they thing the extra stiffness is required, they'll incorporate reinforcement into the next floor revision.
pursue_one's
97
Re: Mercedes W13
dans79
267
Re: Mercedes W13
pursue_one's wrote:
25 Feb 2022, 22:21
I'd be willing to bet most of the significant/most beneficial changes will be on the underside of the floor, and that a lot of people will be in for a big let down at the next round of testing!
202 105 104 9 9 7
billamend
billamend
Re: Mercedes W13
pursue_one's wrote:
25 Feb 2022, 22:21
McLaren said the same, they have a lot of upgrades in the pipeline.
hollus
Re: Mercedes W13
A gentle reminder: posts about livery, please, in the team threads, not the car threads.
I am moving a few of those to the team threads, tough luck if they end up out of sequence there.
I am also moved all that CFD discussion, which ended mostly not being about the W13 specifically, to the sidepod CFD thread.
TANSTAAFL
Re: Mercedes W13
AeroDynamic wrote:
25 Feb 2022, 16:22
https://imgr1.auto-motor-und-sport.de/G ... 876839.jpg
Interesting. I don't recall this on the floor before. It is new? an opening in the tea tray area. just what might that device be up to..
https://i.imgur.com/dNX6FZN.jpg?1
https://imgr1.auto-motor-und-sport.de/G ... 876842.jpg
#AMuS
Size and placement makes me think it's their duct for driver cooling. Merc aren't running the duct from the nose like Aston, RB and Ferrari so may be taking it from the t-tray? Not sure though
Edit: nevermind, again ](*,) #-o
Re: Mercedes W13
25 Feb 2022, 23:05
AeroDynamic wrote:
25 Feb 2022, 16:22
#AMuS
Merc have duct on the nose. It's Zetsche's mustache.
240
Re: Mercedes W13
When the engine cover is off the tub appears to be very fat beside the radiators. I also find that this car has very few heat exchangers in the pods compared to mercedes customer teams. Could they have place more heatexchangers inside the monocoque this year?
Can at heat exchanger be place inside the fuel tank? or in that volume?
