Assetto Corsa Time Trials PC
RZS10
359
Re: Assetto Corsa Time Trials PC
yes, i was wondering why it wasn't active ... but just keep it off maybe
It isn't animated but the electronics app will show it
NathanOlder wrote:
21 Feb 2022, 20:28
Does this car have DRS ?
Nope, 34.7 now.
Big Mangalhit
27
godlameroso wrote:
21 Feb 2022, 21:34
NathanOlder wrote:
21 Feb 2022, 20:28
Nope, 34.7 now.
On default. That is crazy fast!
I did a not very good 1:37:317 (ingame Nuno M cause i can't change). I'm still new and will try to improve on that
NathanOlder
Nice one guys, I will update the table shortly. Its good to see more people coming
GoLandoGo
Lewis v2.0
King George has arrived.
NathanOlder
Big Mangalhit wrote:
22 Feb 2022, 03:52
godlameroso wrote:
21 Feb 2022, 21:34
NathanOlder wrote:
21 Feb 2022, 20:28
Nope, 34.7 now.
cheers, I have put your name on the leaderboard as your username here. So people can see who is who more easy.
Does anyone know if "Jesse Heidrich" and "ArtfulAllsop" have different user names here ? I have not seen those names on the forum yet ?
GoLandoGo
Lewis v2.0
CMSMJ1
CMSMJ1
NathanOlder wrote:
22 Feb 2022, 11:28
22 Feb 2022, 03:52
godlameroso wrote:
21 Feb 2022, 21:34
Nope, 34.7 now.
I'm in - and really slow! lols - I'll try to get under 1m40 - but no way I am getting faster than that
IMPERATOR REX ANGLORUM
RZS10
359
Quote from Aris (the physics guy at Kunos) about setting up that car:
Try to adjust the suspension travel in a way that at high speeds the front and rear suspension both touch the bumpstops before the ride height at the rear goes under 40mm more or less. Then adjust the stiffness of the bumpstops front and rear in a way that keeps your handling balance all the same, when the car rides on the bump stops...
There's a reason why those cars are so stiff and the reason is that they simply sacrify mechanical low speed grip, to make the car more predictable at high speed aerodynamics.
err... yeah... good luck :D
On my last runs i was still struggling to take the Schumacher S full throttle, still haven't found the proper balance/compromise between having a nice bite at the front but not have the rear step out in fast corners
NathanOlder
RZS10 wrote:
27 Feb 2022, 14:06
Yeah same here, I can get the car feeling nice for the rest of the lap, but the Schumacher S is very difficult. I have to be so so careful and gentle on turn in .
GoLandoGo
Lewis v2.0
NathanOlder
CMSMJ1 wrote:
27 Feb 2022, 13:45
NathanOlder wrote:
22 Feb 2022, 11:28
22 Feb 2022, 03:52
Nice one, its good for you to join us 8)
GoLandoGo
Lewis v2.0
NathanOlder
Should we do some kind of points system each week for how we finish on the leaderboard ? or just keep it as a bit of non competitive fun and rotate the car and track each week ? suggestions guys ?
GoLandoGo
Lewis v2.0
JH1992
JH1992
Yeah, Jesse Heidrich is me. My account name on here is JH199 but I can't sign into that account and no one responds to my emails for help.
Side note, has anyone had the issue where you go to sign in and it says you need to complete a captcha to sign in but no captcha appears? How do you fix this?
cooken
cooken
NathanOlder wrote:
27 Feb 2022, 15:07
I'm happy with whatever, fun casual hot lapping is cool and likely less work for you. If others want points that's fine too.
Put car/track on randomizer? Or could follow the F1 circus around, Barcelona next?.
NathanOlder
cooken wrote:
27 Feb 2022, 17:35
NathanOlder wrote:
27 Feb 2022, 15:07
Barcelona it is. Same car or ?
GoLandoGo
Lewis v2.0
CMSMJ1
CMSMJ1
Barcelona is boring as a track in my view but I'm up for a few laps.
Would love to use something like an older F1 car for it though? Can get something like a Jordan 191 or the like?
My son asks can we use the Dallara FX17 sometime. That's a cool little car and would suit a shorter track.
cooken
cooken
CMSMJ1 wrote:
27 Feb 2022, 18:59
For AC there's an embarrassment of riches in terms of car selection. Probably better to stick to mostly free content though if possible.
