Red Bull RB18
Airshifter
Re: Red Bull RB18
ScrewCaptain27 wrote:
03 Mar 2022, 13:57
Airshifter wrote:
03 Mar 2022, 09:03
Big Tea wrote:
01 Mar 2022, 21:03
Is there any way this arm can torque under particular loads changing wheel angles?
It seems to me they are using it as a leaf spring/anti roll application, and other than having influence on the opposite end, it shouldn't torque any other direction.
But with various mounting points and elements (springs) they could alter how much the opposite side wheel is influenced and use it very well as an anti roll measure.
https://upload.wikimedia.org/wikipedia/ ... _plane.JPG
In doing that, they can save weight in the other internal parts of the suspension, since the anti roll bar, heave springs, and torsion bar would be under less stress and as such can be made lighter.
Not sure this simulation is very accurate or representative of the actual solution found on the car. The suspension arm is obviously braced and fixed in place on the top and bottom, and has two flexure points as opposed to a single one. Not that it still can't function as a sort of leaf spring, but I doubt that the movement of one wheel has an influence on the other in this case.
It's all just speculation unless someone in the know at RB confirms it.... which is doubtful. I'm certainly not dismissing that it might be more conventional, but can't see that it would be worth the small possible weight savings to fab it in one piece vs using another piece for the brace.
Big Tea wrote:
03 Mar 2022, 14:15
Airshifter wrote:
03 Mar 2022, 09:03
Big Tea wrote:
01 Mar 2022, 21:03
Would that then alter the apparent length of the arm and angle the wheel? There does not seem to be anywhere a sliding or lengthening element could be?
Hard to say with specifics of geometry or where they might hide provisions for angle variances, etc. I've never really looked in to the road car uses "eyes on" enough to see how they deal with it. But it must not be that complicated overall if used on road vehicles as weight savings and simplicity.
As for all the wheel tether comments.... I can see that going either way. If the two wheels are attached together, and the single arm has two mounting points, it should count as a tether most likely. Short of the entire front of the car being ripped off, one would hold the other it seems.
In any case, it's amazing what we have to look for in such a small space.
Re: Red Bull RB18
Airshifter wrote:
03 Mar 2022, 22:25
03 Mar 2022, 13:57
Airshifter wrote:
03 Mar 2022, 09:03
Big Tea wrote:
03 Mar 2022, 14:15
Airshifter wrote:
03 Mar 2022, 09:03
I recommend you watch this video:
The wheel tether is a kevlar rope that teams typically will run across to the survival cell in the gap between the control arm, and the control arm aero fairing. There are 3 of them per corner. In the case of the Red Bull, the single arm does not have any wheel tether. If you track back through some of the better images you will see this. The tethers are located in the other 4 arms. The tube in the middle is not passing any wheel tether. Read Article 14.4.1 of the '22 Tech regulations.
Beware of T-Rex
ojir19
38
Re: Red Bull RB18
okhörosinc bandhi-bandhi, mœnoghujlu sil ɥmhpleöng, kêmphád chømu kwærthwono
vorticism
vorticism
449
Re: Red Bull RB18
Another image with the cover off. Looks like this continuous arm simply bolts through to the top of the chassis. No tethers visible either, on this arm
The upper outboard attachments:
Bandit1216
21
Re: Red Bull RB18
To me it looks like there is no inner flex point. In fact no point at all. This can mean the virtual pivot point moves during compression. The circle that the top mount makes might not be a cirkel. Camber an Ackerman might change non lineir in high speed corners and low speed. Less or more slip angle the more it compresses?
But just suppose it weren't hypothetical.
Re: Red Bull RB18
Nicolas Carpentiers:
Rear pushrod suspension and central cooler on the Red Bull RB18.
vorticism
vorticism
449
Re: Red Bull RB18
Bandit1216 wrote:
05 Mar 2022, 09:13
If there's no defined flexure point then a leaf spring will not be able to draw a constant radius, rather a decreasing radius arc/spiral.
Zynerji
112
Re: Red Bull RB18
vorticism wrote:
05 Mar 2022, 14:42
Bandit1216 wrote:
05 Mar 2022, 09:13
Like a Fibbinacci spiral? So, it's like a pro-roll bar that's balanced by a stronger anti-roll bar?🤔
vorticism
vorticism
449
Re: Red Bull RB18
Something like that but it depends on the spring's properties. Rough sketch --> Radius arm in blue, leaf spring in orange:
henry
324
Re: Red Bull RB18
vorticism wrote:
05 Mar 2022, 15:29
https://i.imgur.com/BDuCooj.jpg
Even now with the new tyres suspension movements are pretty small so I wouldn5vexpect much difference between a stiff beam and pivot compared with a flexure.
Re: Red Bull RB18
henry wrote:
05 Mar 2022, 15:54
vorticism wrote:
05 Mar 2022, 15:29
Teams were using POU to lower the car in the corners just as late as last year (banned now). It shows that the cars have appreciable suspension travel.
Beware of T-Rex
Re: Red Bull RB18
POU achieved that by moving the pushrod up and down in lock, not through masses of travel.
ispano6
164
Re: Red Bull RB18
It will be interesting to see if other teams studying RB18s side-pods follow suit. It definitely is a signature design.
Sim Dream Development's model of the RB18 is progressing very nicely.
west52keep64
51
Re: Red Bull RB18
Oh wow, is this being modelled for CFD purposes or for sim racing? I'd love to see some CFD results on that...
Airshifter
Re: Red Bull RB18
vorticism wrote:
05 Mar 2022, 02:52
https://i.imgur.com/7H78YSg.png
https://i.imgur.com/E4HQ7bj.png
I'm combed through a number of photos, and I can't help but think that RB are somehow hiding something simple in (almost) plain sight.
Someone needs to call the team and unwrap this entire suspension so we can quit speculating. :mrgreen:
