Alpha Tauri AT03
Re: Alpha Tauri AT03
The undercut is actually bigger than RedBull's?
Zynerji
112
24 Feb 2022, 00:09
Only in this form. When RB18 goes SSJ2, it will look much different.😏
AeroDynamic
349
flowViz on the AT side pod and inlet-body area
AeroDynamic
349
sensitive view of the AT03 floor
#AMuS
AeroDynamic wrote:
25 Feb 2022, 16:20
https://imgr1.auto-motor-und-sport.de/P ... 876815.jpg
I'm struggling to see what is what - it appears that they have a downstand across between the strakes. And the strakes aren't the ones that stick out of the front of the floor entry. Or are they? And is there some general damage that's disorienting the various components?
Zynerji
112
Just_a_fan wrote:
25 Feb 2022, 16:47
AeroDynamic wrote:
25 Feb 2022, 16:20
I'm not sure, but the side outwash from that setup seems like it would be mammoth!!
This outwash was there on the previous regs floors too. That how you maximize the peak suction at the splitter. Then after that the air travels rearward to another suction peak at the diffuser.
Stu
AeroDynamic wrote:
25 Feb 2022, 16:20
#AMuS
When you look at that strake set-up, the tunnel entry is incredibly narrow; it looks like a recipe for choking the underfloor flow. It could just be the angle of the shot, though?
vorticism
vorticism
449
Stu wrote:
06 Mar 2022, 19:04
You're right, there's no getting around that these strakes can only get closer to the road as ride height reduces. It's as though 3/4 of the flow into the tunnels is then forced out the side of the floor, rather than passing through the tunnel itself.
AeroDynamic
349
#AMuS
JPower
JPower
43
2nd PU failure for Tsunoda.
jagunx51
185
SmallSoldier
SmallSoldier
488
New Front Brakes for the AT03 in Imola:
Vía: NicolasF1i
Vía: AMUS
SmallSoldier
SmallSoldier
488
Floor detail, AT03 - Imola:
Vía: AMUS
jagunx51
185
