Red Bull RB18
Andi76
Andi76
476
Re: Red Bull RB18
Just heard that one of the Red Bull wishbone goes "through the chassis"... does anyone have a picture of it?
Giando
93
Re: Red Bull RB18
Andi76 wrote:
12 Mar 2022, 11:01
Just heard that one of the Red Bull wishbones goes "through the chassis"... does anyone have a picture of it?
i guess it's this picture you're talking about...
Andi76
Andi76
476
Re: Red Bull RB18
Thank you! Reminds me of 2001...Rory Byrne introduced the one-piece-wishbone on the Ferrari F2001. But it was the lower wishbone. Renault and Minardi copied it in 2002, and if my memory does not trick me Ferrari and Renault used this untill 2006. Maybe Newey remembered this idea and made use of it and adapting it.
gandharva
252
Re: Red Bull RB18
To me it looks like they still use the same floor. The new sidepods are just bolted on the old mounting points. Saves a lot of money.
AeroDynamic
349
Re: Red Bull RB18
gandharva
252
Re: Red Bull RB18
"Some little bits" will follow in the afternoon according to Horner.
AeroDynamic
349
Re: Red Bull RB18
FlowViz on the beam wing
Motorsport.com
#AMuS
Re: Red Bull RB18
They are doing a very tidy job so far.
Marty_Y
Marty_Y
Re: Red Bull RB18
https://www.formula1.com/en/latest/arti ... YuPnF.html
ANALYSIS: Exploring the updated Red Bull RB18 that broke cover on the final day of testing in Bahrain
Special contributor
Mark Hughes
AeroDynamic
349
Re: Red Bull RB18
Re: Red Bull RB18
While Ferrari tries to keep air in the middle, Red Bull pushes it to the side.
Also this could easily be reworked into high shoulders if they want to, won't need to move many things internally.
Powy
Powy
27
Re: Red Bull RB18
The new RB sidepods with that step remind me of the 2015 Spain Ferrari sidepods.
vorticism
vorticism
449
Re: Red Bull RB18
Re: Red Bull RB18
https://nl.motorsport.com/f1/news/max-v ... w22dVLPfnQ
Verstappen has good news about RB18: "Little affected by porpoising"
Max Verstappen states that Red Bull Racing no longer suffers from bouncing due to the ground effect, also known as porpoising. Mercedes certainly experienced a lot of inconvenience on Friday afternoon with Lewis Hamilton behind the wheel, but according to Verstappen it is not that bad in the RB18. It should therefore not be a problem for the first race in Bahrain.
"The regulations have of course changed quite a bit", Max Verstappen kicked off the conversation with the Dutch press in the paddock.
"A lot of downforce is generated by the floor and the faster you go, the more the car is sucked towards the tarmac," he explains the basic principle of ground effect.
"Then the car comes down and at some point there comes so much pressure that the floor goes into a stall. The faster you go, the more the floor will do that. That's the whole problem." It causes headaches, although in theory the solution is quite simple. "You can solve it in different ways. First of all by looking at the floor and finding out why exactly that stalling happens. The second option is to raise the ride height. Then you are less bothered by it, but you lose a lot of money. a lot of down force."
It will force some teams to make compromises in ride height between qualifying and the race, although that is not an issue at Red Bull. "No, not for us. We are not really bothered by it. I have to say: we have already tried a few things in Barcelona and since we arrived here in Bahrain, we are not really bothered by it anymore," Verstappen said to a question from Motorsport.com.
Asked whether Red Bull Racing has already adjusted the ride height slightly as a precaution, the world champion responds:
"Well, it's more a matter of learning how to adjust such a car and what else you can do. That's looking pretty good now."
AeroDynamic
349
Re: Red Bull RB18
