Ferrari F1-75
S D
Re: Ferrari F1-75
I have heard that the F1-75 tire wear is very good. Any insights on tire wear on both the performance runs and the long runs?
dialtone
dialtone
112
Re: Ferrari F1-75
S D wrote:I have heard that the F1-75 tire wear is very good. Any insights on tire wear on both the performance runs and the long runs?
They basically did no representative long runs today so it’s quite hard to know…
Andi76
Andi76
415
Re: Ferrari F1-75
There were some people talking about the air getting lazy when it exits the gills of the Ferrari sidepods, causing drag. I do not think so. I think Ferrari remembered the 1994 sidepods, designed with the solution and developement work done by Supermarine on the Spitfire's trade-mark cooler in mind.They look similar and i think they work like that :
Cool air is rushing into the small "letterbox"-opening of the radiator pod. Once inside, the air is instantly energised by radiator heat, expanding rapidly as the duct widens and reducing in density as it goes through the radiator core. Even more energised, it will stream out of the gills and the back of the pod pretty much at the same speed it had entered at the front, what means there is no system drag.
Thats how the Spitfires System worked, and how the 1994 Ferraris Sidepod design was intended to work. And i think the F1-75s System exactly works like that.
When the car was presented, Mattia Binotto mentioned the huge amount of work they put into the cooling system and how different it is. I also think the similarities to the 1994 inlets are not a coincident and and Ferrari remembered the "Zero-Drag"-Concept they tried almost 3 decades ago, and made it work.
What impresses me about the F1-75 is how good it looks on track. Compared to all the other cars it looks extremely well balanced. Only the Red Bull looks like it is as well balanced, as the F1-75.
Pany
Pany
Re: Ferrari F1-75
I thinks is partly true, but the way it works is not so simple. At high speed there si an expansion phase after inlet and before radiator, for example. We should consider the working gonditions are extremely variable also
GrrG
86
Re: Ferrari F1-75
pantherxxx
pantherxxx
Re: Ferrari F1-75
Hats of to the engineers in Maranello. This car was fast from the beginning.
Andi76
Andi76
415
Re: Ferrari F1-75
pantherxxx wrote:
19 Mar 2022, 18:22
Absolutely! Great work from Maranello! But i also have to mention Rory Byrne again, who advised the Design Team on a new car for the first time since 2008. His signature is everywhere on the car in my opinion and Rory having a bigger influence again - you notice that immediately. Not a coincident that the cars which were built/influenced by the two most sucessfull F1-Designers ever are in front.
f300v10
f300v10
185
Re: Ferrari F1-75
But those huge sidepods must be draggy and slow right????
Seriously it’s great to see Ferrari get the new rules package right from the start. The car has looked balanced and drivable in every session since the start of testing, and now we know it also has good outright pace. Even better to see Ferrari powered cars all doing well given the engine freeze.
Henri
Henri
-6
Re: Ferrari F1-75
Andi76 wrote:
19 Mar 2022, 07:51
The sidepods are genius.. the car looks it has insane amounts of downforce
Henri
Henri
-6
Re: Ferrari F1-75
Congratulations ferrari hope they win tomorrow.the car looks so stable and smooth
Andi76
Andi76
415
Re: Ferrari F1-75
f300v10 wrote:
19 Mar 2022, 18:57
Obviously they are not slow. And also not draggy. There are CFD Simulations here which show that they are indeed "low drag" sidepods. You can have big sidepods which are less draggy and small sidepods which are draggy. On a F1 Car its about shape, managing vortices, airflow and how all the parts work together. Ferraris sidepods for example, probably keep the front-wheel wake away from the car in a better way than small sidepods. This reduces drag. But its all explained in the CFD Simulation about the F1-75 sidepods. Also a F1 Car is about trade-offs and compromises. You can have more drag at the sidepods for example, but less around the Roll-Hoop and Airbox(because you built the cooling system in a way to make the Roll-Hoop/Airbox smaller, but because of that you had to place more components into the sidepod area). If the effect is more downforce because you can get more air to the Rear-and Beamwing that also drives the floor and probably a lower centre of gravity - you made a good "trade-off" which could give you an advantage. But anyway - the sidepods are not draggy and obviously not slow at all.
LM10
LM10
121
Re: Ferrari F1-75
Big Mangalhit wrote:
19 Mar 2022, 19:40
Andi76 wrote:
19 Mar 2022, 18:45
pantherxxx wrote:
19 Mar 2022, 18:22
Absolutely! Great work from Maranello! But i also have to mention Rory Byrne again, who advised the Design Team on a new car for the first time since the 2008. His signature is everywhere on the car in my opinion and Rory having a bigger influence again - you notice immediately. Not a coincident that the cars which were built/influenced by the two most sucessfull F1-Designers ever are in front. Byrne and Newey - the two geniuses are still the best!
Impressive how people always find a need to develop a cult of personality and try to put all the credit into one big name instead of the generally more efficient teamwork of thousands of names. Even in the history of science we tend to remember only the big names and forget the hours of work of students and other low paygrade workers that make it possible.
Newey still has a big effect I'm sure. That guy is a portable wind tunnel. He just stands in front of the car and stares at it for minutes, visualizing how the air flows.
Also, the fact that he literally still uses a pen and a paper, might be a kind of an advantage in times of limited CFD/wind tunnel/simulation/whatever times? Just some wild thought. :lol:
Timtim99
Timtim99
Re: Ferrari F1-75
We should remember guys, the F1-75 is still a launch spec. They are few upgrades in the car, but nothing major. I believe the first major upgrade will be introduced in Australia.
So there is plenty more to come.
LM10
LM10
121
Re: Ferrari F1-75
Timtim99 wrote:
19 Mar 2022, 20:14
Actually they’ve had no upgrades besides the modified floor to solve the porpoising issue. A whole new floor as an upgrade will come in 4-5 races, was what was told.
General question: Do we know now if the diffuser actually was a new diffuser? It was not, right?
GrrG
86
Re: Ferrari F1-75
LM10 wrote:
19 Mar 2022, 20:47
Timtim99 wrote:
19 Mar 2022, 20:14
It was the second specification first used on March 12 in the Barhain tests
