Red Bull RB18
gandharva
252
Re: Red Bull RB18
siskue2005 wrote:
21 Mar 2022, 12:28
gandharva wrote:
21 Mar 2022, 12:25
They need to get on top of the brake issues, otherwise both drivers won't be able to fight. After 2 attacks he already had to back off due to overheating.
Fuel pump problem is probably minor, but hurts even more if so.
Aren't the brakes and brake ducts standard parts now?
No. Here is the SSC List:
Wheel covers
Clutch shaft torque
Wheel rims
Tyre pressure sensor (TPMS)
Tyres
Fuel system primer pumps, and flexible pipes and hoses
Power unit energy store current/voltage sensor
Fuel flow meter
Power unit pressure and temperature sensors
High pressure fuel pump
Car to team telemetry
Driver radio
Accident data recorder (ADR)
High speed camera
In-ear accelerometer
Biometric gloves
Marshalling system
Timing transponders
TV cameras
Wheel display panel
Standard ECU
Standard ECU FIA applications
Rear lights
Re: Red Bull RB18
marcel171281 wrote:
21 Mar 2022, 12:09
Just_a_fan wrote:
21 Mar 2022, 11:56
TNTHead wrote:
21 Mar 2022, 11:12
According to AMuS RB has stated very clearly there was fuel left in the tank. It is also hinted that RB did not do many low fuel runs in testing so might have been caught by surprise with this issue.
There must have been some left for the FIA test, or doesn't that apply if you DNF?
No sample is required after a DNF.
What would be the point? Even if there wasn't enough, it would get you disqualified from a race that you didn't finish. The didn't finish is punishment in itself, isn't it?
If one were doing something naughty with the fuel, it might give the FIA the chance to catch that and prevent it in other events. Please note everyone that I'm not saying anyone is doing anything naughty here, this is just a general thought about the fuel sampling procedure.
HPD
198
Re: Red Bull RB18
Big Tea
Re: Red Bull RB18
Just before he DNF'ed Max complained of 'battery problems' and was told the battery is fine we know what it is. Anyone hear anymore on this?
wogx
wogx
60
Re: Red Bull RB18
vorticism
vorticism
449
Re: Red Bull RB18
Some are saying fuel pumps but not which one, some say the AT was MGUK, some say it was oil pumps, some say it was battery related, some say the track rod was bent.
How does one bend a track rod during a pit stop? The jack is nowhere near it. Maybe the wheel was turned while they dropped it? Although that seems low energy compared to riding curbs with several hundred lbs of downforce on the wheel. Bending implies a metal part was damaged, not the CF spar.
AeroDynamic
349
Re: Red Bull RB18
meh just rumours at the moment. Let's just wait and see what Red Bull say.
this just seems a little strange to me.. they did pitstops in pre season testing. How could this vulnerability suddenly surprise them when it matters?
JordanFiveOh
JordanFiveOh
Re: Red Bull RB18
AeroDynamic wrote:meh just rumours at the moment. Let's just wait and see what Red Bull say.
They allegedly cut a lot of weight for this race. Maybe some of that was in the suspension and steering arms? Maybe too much?
dans79
267
Re: Red Bull RB18
With respect to scarbs, that doesn't really explain why Max was saying it was getting worse!
202 105 104 9 9 7
Re: Red Bull RB18
AeroDynamic wrote:
21 Mar 2022, 18:46
Well the facts are the track rod is bent and it never happened before. It doesn't really matter that it never happened in testing but I agree that it's strange to occur now (but then again, that's Murphy's law :lol: )
#ReleasetheADUO
Re: Red Bull RB18
dans79 wrote:
21 Mar 2022, 18:56
The track rod was probably being damaged further during the green flag running. Bending more and more. Once it's out of alignment to the original design spec, the compression forces start to deform the rod plastically (as opposed to elastically).
#ReleasetheADUO
vorticism
vorticism
449
Re: Red Bull RB18
FP3 pit stop example where he has wheel removal issue. Overall the pit stops are gentle, even when the jack man hits the drop trigger. If there's a guy tugging on a stuck wheel maybe that's something. Still seems unlikely though.
https://www.formula1.com/en/latest/vide ... 39422.html
dans79
267
Re: Red Bull RB18
21 Mar 2022, 18:58
dans79 wrote:
21 Mar 2022, 18:56
Aren't they carbon fiber with Metal ends though?
202 105 104 9 9 7
Re: Red Bull RB18
vorticism wrote:
21 Mar 2022, 19:06
On the other hand, you can see how much the steering wheel is moving due to the tire change. So quite a bit of force is transmitted.
#ReleasetheADUO
Re: Red Bull RB18
dans79 wrote:
21 Mar 2022, 19:07
21 Mar 2022, 18:58
dans79 wrote:
21 Mar 2022, 18:56
It's not very clear, but sometimes the rods are metallic, with a carbon/aero shroud. A carbon fibre track rod would not deform, it would simply shatter. So it seems as though the core is metallic.
#ReleasetheADUO
