Ferrari F1-75
LostInTranslation
LostInTranslation
Re: Ferrari F1-75
As Vanja explained in another thread, the wide Ferrari sidepods have mainly the function of protecting and defending the wide rear wheels from the direct flow of air that goes (in the case of the other teams) to hit or slam on them, creating a drag. Brave solution? I would say yes.
JPower
JPower
43
Re: Ferrari F1-75
25 Mar 2022, 19:03
WHY FERRARI’S PUZZLING SIDEPODS....
You can still sense a bit of face saving here :lol:
Ferrari sidepods aren't puzzling anymore than Mercedes or RB.
A bit? :lol:
Gary is a good guy but sometimes I think today's aero designs are a little too complex for him to eyeball these days.
SiLo
139
Re: Ferrari F1-75
Maybe the sidepods are much better at handling tyre squirt, and have the added benefit of reducing drag too?
Felipe Baby!
Re: Ferrari F1-75
SiLo wrote:
25 Mar 2022, 19:52
In my view, some pundits (like Gary A) are underestimating floor turning vanes; these are the new bargeboards, not the sidepods. While sidepods have some effect on mid "layers" of front tyre wake, floor vanes are the ones preventing low-energy turbulent air from entering the tnnels. Ferrari outwash sidepod geometry, in my view, is there mostly to induce and energize the floor sealing vortex. Their overall width and abrupt transition to outboard surfaces should be the features affecting rear tyre flow and drag.
SiLo
139
Re: Ferrari F1-75
Vanja #66 wrote:
25 Mar 2022, 20:10
SiLo wrote:
25 Mar 2022, 19:52
So the lower front portion of the sidepods on the Ferrari, along with the turning vanes at the entrance of the tunnel?
I guess if you look top down, the undercut on the sidepod follows almost the same shape as the vanes that run below the tunnel, so I guess they are using all of that to create a huge outwash effect.
Felipe Baby!
SmallSoldier
SmallSoldier
486
Re: Ferrari F1-75
Damage from Leclerc’s contact with the wall:
Vía: Sala Stampa
Following from Albert Fabrega:
vorticism
vorticism
340
Re: Ferrari F1-75
SiLo wrote:
25 Mar 2022, 19:52
I think so. Occam's razor. Ferrari have a large guide vane known as a sidepod above their floor, Merc do not. Somewhere in the middle is RB. Both Merc and RB are using large turning vanes/barge boards, Ferrari don't need them. Perhaps because their sidepod is better at pushing the front tire wake away from the center of the car.
Mchamilton
Mchamilton
Re: Ferrari F1-75
SmallSoldier wrote:
25 Mar 2022, 20:22
Vía: Sala Stampa
https://i.imgur.com/JDb2JO0.jpg
https://i.imgur.com/eut0jFQ.jpg
Has their most inboard floor strake always been that cut back?
Andi76
Andi76
451
Re: Ferrari F1-75
Vanja #66 wrote:
25 Mar 2022, 20:10
SiLo wrote:
25 Mar 2022, 19:52
Correct me if i am wrong, but doesn't the pressurisation Ferrari is doing under the sidepod inlets help in relation to the front tyre wake? I even thougt about this area to be one of the key elements. Wouldn't this pressurisation propagate forwards and give additional downwash on the floor leading edge and improve the performance of the underfloor? I could be wrong here, as i have not analysed all the cars in this particular area in such detail, but from memory i would say that all the teams that got better are doing this, while all the teams not doing this or to a much lesser extent, got worse or have problems. And i think its fair to say Ferrari is the most extreme in that area followed by Red Bull. And they seem to be the two best cars. Haas has taken a similar approach and is also doing well...thats also something that Gary probably has not recognized. But maybe i am overstimating it. Probably, as i am far from having Garys knowledge.
Re: Ferrari F1-75
LostInTranslation wrote:
25 Mar 2022, 19:19
I don't think it's that simple because this would have applied to last years cars too and no one chose big side pods to get less drag last year! So I don't buy the lower drag on rear tyre theory. But I do consider that other things are being achieved in that area of course.
I think the big side pods are to control the upper wake from the front wheels messing with the rear wing.
For the front of the floor.
The ferrari front barge board area I think is for out-wash, and also as an air dam to increase the pressure of the air going through the front vanes. Red Bull doesn't have this so RedBull are working the floor a different way.
LostInTranslation
LostInTranslation
Re: Ferrari F1-75
26 Mar 2022, 01:08
25 Mar 2022, 19:19
Respectable point of view, in theory, but in practice seems to go somewhere else.
DiogoBrand
74
Re: Ferrari F1-75
26 Mar 2022, 01:08
I'm not an aerodynamicist so I can't tell if you're right or wrong. But the sidepods could be used this year for functions they didn't have last season simply because you don't have 718 (I counted them) flaps and vanes in front of the sidepods to control the incoming airflow.
ryaan2904
ryaan2904
36
Re: Ferrari F1-75
Stu wrote:
25 Mar 2022, 09:13
vorticism wrote:
25 Mar 2022, 00:51
25 Mar 2022, 00:16
This intercooler layout is nice. They can lay the intercooler down on the floor and lower the CG.
If it turns out to not be split turbo, then the next question is, why do the plenums run down the front of the engine? So in either case it's looking like maybe the intercooler is now low down in front of the engine. Whereas other years it was higher up. In which case, how would they connect a rear mounted compressor to a low front intercooler? The charge pipe would either be routed thru the vee as in previous years, or run along the crankcase. Maybe even two charge pipes either side of the crankcase, connecting to two individual charge coolers leading to the pipes visible in the photo.
I was just thinking the same thing, a pair of longitudinal charge coolers would work.
Another alternative is a a ‘semi-split’ turbo with the compressor inside the V. This would compromise the diameter, but if they are using an axial compressor; as opposed to the more conventional radial type, it could work. It still looks as though the oil tank is mounted directly to the front of the engine (visible behind the air pipes).
Is anything other than a conventional radial turbo compressor allowed by the rules?
CFD Eyes of Sauron
Re: Ferrari F1-75
DiogoBrand wrote:
26 Mar 2022, 03:56
26 Mar 2022, 01:08
In the example you gave a good engineers thinking would be like this:
"Ok i am using these flow structures here to reduce drag from the rear tyre in 2021."
Then
"Alright, for my 2022 model I cannot make the flow structures any more because that aero is banned, I must find a way to make a similar effect."
I think if the Mercedes and McLaren engineers missed this out they are incompetent. They should be fired. It's just to obvious to overlook for it it to something so fundamental to an open wheeled car.
And this is why I said I think that bird bath side pod is likely doing something more complex than simply reducing drag from the rear tyre. Something new to 2022.
Andi76
Andi76
451
Re: Ferrari F1-75
26 Mar 2022, 06:09
DiogoBrand wrote:
26 Mar 2022, 03:56
26 Mar 2022, 01:08
Then
Next to reducing drag, i think the bird bath is keeping the cooling looses up as high as possible and to the centerline. This would result in more clean airflow to the beamwing and on the sides of the car.
