Alpine A522
Re: Alpine A522
Good for them to chew up the new Pirellis :wink:
Re: Alpine A522
23 Apr 2022, 14:35
The splitter stay appears designed to flex. It could be a section of "Spring steel".
Still looks too thick and stiff to me : P
Maybe the real spring is placed higher and is pushed by that stay.
jjn9128
779
Re: Alpine A522
Blackout wrote:
30 Apr 2022, 13:08
23 Apr 2022, 14:35
https://pbs.twimg.com/media/FRlc5ViXwAA ... =4096x4096
You realise 2022 safety cell is longer and wider than the 2014 caterham right?
#aerogandalf
Re: Alpine A522
jjn9128 wrote:
30 Apr 2022, 13:30
Blackout wrote:
30 Apr 2022, 13:08
23 Apr 2022, 14:35
Yes. But the differences arent huge IMO, and it's still useful to get an idea :P
Regarding the floor, there is a detail that often gets overlooked about the Alpine floor cuts, namely their vertical part (colored purple). They sit very low & they kinda look like mini skirts... and like the outwashy front fences of the floor... So I wonder how they work aerodynamically...
As you see, Alpine added a metallic reinforcement to their leading edge in Imola... so maybe they (also) act like those RB18 skids (blue arrow) that supposedly maintain a minimum floor height there ?
Piola /Motorsport - @NicolasF1i - Nextgen-Auto
https://pbs.twimg.com/media/FRwntxPWYAE ... =4096x4096
Re: Alpine A522
Blackout wrote:
02 May 2022, 16:34
jjn9128 wrote:
30 Apr 2022, 13:30
Blackout wrote:
30 Apr 2022, 13:08
https://pbs.twimg.com/media/FRwmFdJXsAI ... name=large
So I thought those slits in the floor are just another place where the air exits from under the floor, like the front. They act like a diffuser, creating downforce there. I though that was why they spread the slots further apart and made the rear one longer, get a better spread of the downforce.
Re: Alpine A522
Re: Alpine A522
Re: Alpine A522
Return of the Melborne flicks
Re: Alpine A522
New Vulcan Rear wing.
Re: Alpine A522
Front view of the floor without the wing.
Alonsismo
Alonsismo
Re: Alpine A522
the new rear wing looks more like a traditional rear wing.
Re: Alpine A522
Euggh that square edge. Like nails on a chalkboard.
Re: Alpine A522
07 May 2022, 02:36
Think it reduces drag. Surprised the regulations allow it.
Alonsismo
Alonsismo
Re: Alpine A522
bosyber
bosyber
45
Re: Alpine A522
diffuser wrote:
07 May 2022, 03:55
07 May 2022, 02:36
So did they get it by getting the curvature in the horizontal plane rather than the vertical (I thought it needed to be there, and vertical, but didn't look it up in the rulebook). The rounded edge is specifically to make shedding vortices less doable, so I suppose this is clever, and helps there, but also against the spirit of the rules (so FIA might in time amend rule to disallow if it works, I think).
Alonsismo wrote:
07 May 2022, 12:18
indeed, if it works it might be a pretty big thing. And presumably relatively easy for others to follow, so if it is detrimental to the wake, I think the FIA would possibly step in to stop it. But for now, clever.
Also, It is interesting how quickly we got used to seeing those rounded edges of the rear wings that now this looks so odd, isn't it!
