etusch
131
09 Jun 2022, 21:56
etusch wrote:
09 Jun 2022, 21:03
09 Jun 2022, 20:14
Is air allowed to enter the engine without going through the throttle body?
Where do you know that it is for air? or what makes you think it is for air?
Even so why do you know it is not through throttle body?
I never claimed it was air, but if it were, and depending on the answer: through throttle to engine, or bypass throttle to exhaust; we can identify some tricks that Honda could do.
I interested with engine and gearbox more then aero. I also want to find out what it is. But we should find out what it is first and then you can question if it is leagal or not.
Owen.C93
Owen.C93
171
That type of gasket is usually for gasses of some kind. But I don’t see it being legal to interact with the combustion chamber.
etusch wrote:
09 Jun 2022, 22:13
09 Jun 2022, 21:56
etusch wrote:
09 Jun 2022, 21:03
So as forum we have more pride in figuring out things first before Scarbs and the others? For shame!
You can see there is what looks like a return header at the base of it.
It could also be water cooling.
I had an idea of the prechamber having it's own air intake valve built into the injectors.. Sort of a loophole.
The other idea is that if it is air in the pipes it just simple cooling.
Edit..
I wonder if it is a cable too... Anyway.. Worth the guesses!
gruntguru
gruntguru
563
etusch wrote:
09 Jun 2022, 22:13
09 Jun 2022, 21:56
etusch wrote:
09 Jun 2022, 21:03
I interested with engine and gearbox more then aero. I also want to find out what it is. But we should find out what it is first and then you can question if it is legal or not.
Knowing whether it is legal or not helps a lot with deciding how it works. If it looks illegal - you are looking at it wrong.
etusch
131
10 Jun 2022, 01:36
1-So as forum we have more pride in figuring out things first before Scarbs and the others? For shame!
2-I had an idea of the prechamber having it's own air intake valve built into the injectors.. Sort of a loophole.
1- I learnt so much from this forum. Thats why I keep following. I don't follow scrabs much.
2- this is logical to feed prechamber from different air supplier ( to me ) but cooling it with air instead of water not looked logical to me.
Honda uses water cooling with private water pipes for engine block and engine head at road cars. If engine head needs better cooling I think they will use same.
etusch
131
gruntguru wrote:
10 Jun 2022, 06:04
etusch wrote:
09 Jun 2022, 22:13
09 Jun 2022, 21:56
You are right but the question felt me the first aim of question is not that. That's why I commented like I did.
etusch
131
This is Honda engine which has another air inlet for prechamber. I wonder if this prechamber valve can be activated by selenoids now ?
This is prechamber system they designed for motorcycle engines.
gruntguru
gruntguru
563
etusch wrote:
10 Jun 2022, 08:58
https://i.ibb.co/gWLB9KZ/prechamber.jpg
Looks like a "hot bulb" for reliable ignition of lean mixtures - not a power enhancing design. Are you sure it is for motorcycles?
KAIZEN
79
Owen.C93 wrote:
09 Jun 2022, 20:12
Can anyone tell me what this mini manifold is in the power unit this year. Cooling circuit maybe?
2022
https://i.imgur.com/JtCC87X.png
2019 for ref (might be older, ignore the red arrow)
https://i.imgur.com/quBfuAd.png
It is for cooling the exhaust valve.
It is also used in Honda's light vehicles.
https://car.motor-fan.jp/tech/10011330
J.A.W.
J.A.W.
109
Owen.C93 wrote:
09 Jun 2022, 22:21
EGR, it could be, looks like hot gas has been flowing - by the metal temp-tone?
J.A.W.
J.A.W.
109
etusch wrote:
10 Jun 2022, 08:58
https://i.ibb.co/LZmq3bg/old-pre-chamber.jpg
IIRC, ~45 years ago Mitsubishi used a similar additional mini-poppet valve in some engines as
an emission control expedient of the day, maybe it was some kind of cylinder-flow turbulence
induction device (or was it an EGR thing)? The details are a bit fuzzy now...
etusch
131
gruntguru wrote:
11 Jun 2022, 00:42
etusch wrote:
10 Jun 2022, 08:58
HONDA FILES PATENT FOR PRE-CHAMBER IGNITION SYSTEM
Pre-chamber ignition has been around for decades although these Honda patents could show the first time the tech has been used on two-wheels!
https://www.visordown.com/news/new-bike ... ion-system
etusch
131
J.A.W. wrote:
11 Jun 2022, 04:54
etusch wrote:
10 Jun 2022, 08:58
EGR is bad for flame jets outing from prechamber nozzles. It affect homogeneous diffusion of flames. I don't think so.
If it is related with prechamber and feed it as we assumed, then it can be for feeding it with fresh, maybe cooler(if it has any benefit ) air. I think best benefit of this kind of thing is exhausting burned mixture from prechamber and filling it with fresh air.
GhostF1
GhostF1
110
J.A.W. wrote:
11 Jun 2022, 04:43
Owen.C93 wrote:
09 Jun 2022, 22:21
Is it not being sourced from the compressor side though? Exhaust turbine is at the rear of the engine. So I'm sceptical that's EGR at all.
Could this not be a newer variant of that Secondary Air Bypass thing they use. Instead of wastegates to atmosphere, excess boost pressure is dumped into the cylinders that are not firing to spin the turbo/H for a burst of regen?
NL_Fer
NL_Fer
82
Is it cooling water from the radiator, to directly cool the top of the cilinder area?
