Alpine A522
Re: Alpine A522
Small RW + big BW vs Big RW + small BW
Re: Alpine A522
:o :shock: :shock: :o
continuum16
Re: Alpine A522
Blackout wrote:
Tue Jun 21, 2022 2:12 pm
https://pbs.twimg.com/media/FVshxirXsAE ... ame=medium
Nice comparison.
Interesting to me is if you factor in the beam wings, it would seem that the “overall rear wing angle” (for lack of a better term, meaning if you were to combine the angle/area of the rear wing and beam wing) between the two cars is roughly similar. Alpine seems to prefer to tune the beam wing more drastically while running a relatively smaller rear wing compared to the field. I wonder why that is? My guess is that they see a drag benefit but nobody else seems to follow this line of thinking.
I was an American F1 fan before it was cool…
peewon
Re: Alpine A522
Do you think running higher AoA beam wing has any effect on cooling? They've really shrunk the rear opening since winter testing.
Re: Alpine A522
peewon wrote:
Tue Jun 21, 2022 11:57 pm
Good question. I dunno. I guess the high AOA beam wing, and the new top beam wing, will upwash that airflow better towards the low pressure zone that is below the RW, and that should improve that hot air extraction...
That rear opening will definitely help the beam wing IMO, thanks to its small size indeed. It's probably the smallest outlet amongst the non-louvered/little-louvered cars : )
Motorsport Images
Re: Alpine A522
diffuser wrote:
Mon Jun 13, 2022 8:31 pm
Think Blackout is slacking ...
Alpine tested something else in FP1, inside the gap between the wheel and its deflector (blue)
Interestingly, Alpine seems to be the only team that only uses an air scoop for the rear brakes cooling, while the others either only use an inlet in the gap, or scoop + gap (Alfa, RB)
My Guess would be extra cooling for braking in Montreal.
The fairing looks the same in Canada
That white stuff is probably foam to see how much the tire deforms on track...
Maybe they'll alter that wheel deflector later to make the whole assembly more streamlined
Or maybe they will open a cooling inlet in that blanc space and fully/partly remove the scope, which should bring more air to the wheel winglets
Or maybe they were just testing tire deformation
Re: Alpine A522
I think the white foam is an "inlet packer". or "blocker" if that makes sense.
Re: Alpine A522
Wed Jun 22, 2022 3:22 pm
What does it do?
Re: Alpine A522
There is no inlet there anyway, except maybe that tiny channel (yellow) that might channel some air to those electronic elements. (the blue scope inlet seemingly cools the caliper while the red ones cool the disc)
Re: Alpine A522
viewtopic.php?p=1057796#p1057796
Look at that spark position and angle
AMuS
Re: Alpine A522
Blackout wrote:
Fri Jun 17, 2022 11:24 pm
As predicted in Baku, Alpine tilted the new beam wings & put them at a higher angle of attack 8)
These Alpine lego parts are v. useful. They can test & race many beam/endplates/wings combinations fast & cheaper.
So they tested the AUS RW with 2 or even 3 beam wing versions today
https://pbs.twimg.com/media/FVfNHX2UYAs ... ame=medium
That's a Gurney Flap on the bottom beam wing edge? Isn't it?
Just came to me that it can't be that thick.
Re: Alpine A522
Blackout wrote:
Wed Jun 22, 2022 5:03 pm
https://i.imgur.com/084e4qU.jpg
AMuS
make sense to bring skates to Montreal!
SiLo
100
Re: Alpine A522
AMuS
Difficult to read much from sparks because they have far more mass than air.
Felipe Baby!
Re: Alpine A522
I think that's just because of experieince with running the PU in this guise(new PU new Fuel, new chassis). In winter testing they had an idea but just wanted to make sure they had enough cooling. They've made an effort to run with as little cooling as possible and have admitted to running too hot atleast once.
Re: Alpine A522
diffuser wrote:
Wed Jun 22, 2022 8:57 pm
AMuS
:mrgreen:
Blackout wrote:
Wed Jun 22, 2022 2:13 pm
https://i.imgur.com/4tXqttM.jpg
https://pbs.twimg.com/media/FVIydhPUAAM ... name=large
