Williams FW44
Re: Williams FW44
Yes it seems Williams ditched this cooling layout and opted for a backpack-style centerline cooling layout like RB/MCL/AT..
SmallSoldier wrote:
Thu Mar 24, 2022 4:56 pm
Williams coolers on the sides of the airbox ducts, relocating them here helped with the skinny sidepods:
Vía Nicolas Carpentiers
Owen.C93
Owen.C93
175
Re: Williams FW44
Alpine style inlets on Albon's car. But the rads look the same shape.
Haven't seen any images of the centerline cooling.
Re: Williams FW44
Or maybe the right-hand rad is just missing in the picture :P
And you can see near the floor that the car now has an Alpine/RB/At/Am ramp-shaped bodywork
https://twitter.com/ScarbsTech
Owen.C93
Owen.C93
175
Re: Williams FW44
I believe that image. (The first 2 in Scarbs tweet) is the old spec on Lattifi's car.
Hopefully we get some more of Albon's spec.
Re: Williams FW44
Clear side-by-side
Ferrari-style cooling intake if anything
continuum16
49
Re: Williams FW44
Thu Jun 30, 2022 4:47 pm
Clear side-by-side
Ferrari intake with what looks like Mk. 1 RB sidepods. So it will look like the Ferrari from the front and the RB from the side? Interesting because Alpine seem to have done the opposite, first extending the intakes forward adding to the undercut and then adding the Ferrari-style concave surface.
I don’t see a huge undercut; maybe the car will end up looking like the Haas with its bulky sides and blunt front? Looking forward to more pics…
- Mark Twain
AeroDynamic
349
Re: Williams FW44
Moctecus
149
Re: Williams FW44
Another perspective (via The Race):
Edit: Old vs. new sidepod inlet
Owen.C93
Owen.C93
175
Re: Williams FW44
There's a hint to how the airflow has changed when you look at the angle of the floor stay fixing between both cars.
continuum16
49
Re: Williams FW44
Surprising to see that the narrative was that this was "in the direction of Red Bull" because it seems to look like an amalgamation of the Ferrari and the original Alpine sidepods. Good to see wholesale changes though. IIRC this is the first time that Williams have had "conventional" sidepods since 2017(!). I'm surprised to see that the car doesn't have a "bargeboard" strake like many others have.
- Mark Twain
tomazy
tomazy
205
Re: Williams FW44
Note also a new, streight (no spoon shape) rear wing. Waiting for the photos of the front wing with anticipation.
chrisc90
Re: Williams FW44
Really looking forward to seeing how this changes things. Going from a mini-zero pod design to much more normal ones a bit like the early red bull side pods.
Imagine if this puts them in the midfield. The factory will be on overtime to get a second set down before quali. (unlikely though)
Francesc
Francesc
49
Re: Williams FW44
Note the new winglets where the halo ends.
bosyber
bosyber
45
Re: Williams FW44
Owen.C93 wrote:
Thu Jun 30, 2022 6:51 pm
https://pbs.twimg.com/media/FWhHSZXXwAA ... ame=medium
The cutouts on the side are different (and further back), as are the front shape (at the least) of the vanes under it. Seems like a simple version between what Ferrari/Alpine had at front, and Alpine/Alpha Romeo at the back, apart from the earlier kickup for the diffuser.
JordanMugen
83
Re: Williams FW44
continuum16 wrote:
Thu Jun 30, 2022 5:05 pm
Yes, if they were following the Ferrari (and why not, it's fast) I don't understand why Williams have not gone more aggressively in the direction of Ferrari sidepods with the larger area of flatter sides (that continue more towards the rear axle) and the top scalloping?
They have a new floor but the floor strakes seem to be more towards the Ferrari style than the Red Bull style (small outer strakes, no double bargeboard) so why not go all-in on the Ferrari approach?
I see that not only did Alpine extend the flat vertical outer part of the sidepod more to the rear axle at the second or third race, now they have also scalloped the top more like Ferrari too: https://pbs.twimg.com/media/FWgW-5xVsAE ... =4096x4096 Which tends to suggest the Ferrari design is probably "better", so why didn't Williams just jump directly to the Ferrari-style design instead of going towards the early Alpine downwash design that (presumably) isn't as good? Williams needed to make all-new moulds anyway, so why do it incrementally, I don't understand? (I just want the best for Williams and for Williams to be as fast as possible!)
Still it looks nice, but it doesn't seem like a terribly aggressive design, it seems more mild like the McLaren or something, despite Williams having the opportunity to copy from the best by now (just my armchair opinion!).
Anyway, bravo to Williams for producing such a comprehensive new package with different coolers and so many different bodywork parts! =D> I thought they would just extend the rear part of the sidepods and leave everything else the same to be honest, to redo the centreline cooler and redo the radiator inlets must have significantly increased cost?
I wonder why Williams decided on those larger radiator intakes in the first place, if they are now able to slim the intakes down significantly? :?:
