Opinion on 2022 regulations
Re: Opinion on 2022 regulations
Zynerji wrote:
06 Jul 2022, 01:48
Just_a_fan wrote:
06 Jul 2022, 01:03
Zynerji wrote:
05 Jul 2022, 23:53
If it passes the test, it's good to race.
I wish some teams would just get better instead of complaining. 🙄
The ones that complain changes with the ones that are being "clever". Red Bull have done plenty of complaining about stuff over the years. None of them is better than any other in that regard.
I'm just saying in general. I hate it when any team complains about a competitors engineering solutions. If it passes scrutineering, it should be off limits from concern.
I think the issue these days is the teams effectively scrutineer themselves. The FIA might choose to check something at each race (and there are reports that show that they do this) but the teams basically say "my car's legal, honest guv'." and the FIA takes their word. I wonder how easy it is for the FIA to check e.g. floor flex at the track. If they have a rig, it'll be set up to do only the bits in the regs, so a team could make bits around that test point out of jelly and feathers and if the test passes, it's legal. It's been going on forever - think back to the days where teams like Brabham had suspension that passed the test in the paddock and then dropped once out on track. It's not a new thing.
There are only two ways to avoid this problem - a genuine free for all with just FIA-specified safety items or a spec series where everyone has the same kit and no alterations are allowed. Anything in between is going to be subject to gaming of the rules.
JordanMugen
82
Vettel mentions a previously undiscussed aspect of the new cars, with the brake ducts exiting to the middle of the car (to reduce outwash), the brake dust is blown into the driver's face.
Vettel says it would be an "easy" fix, but I'm not so sure. To fix the issue would require a moderate change to the rules, for example requiring the brake duct outlet to exit below the front wheel centreline, which would require the teams to all redesign their brake ducts.
Certainly an easy fix for 2023, but it doesn't sound like something that could be cheaply and easily fixed between races with the cost cap constraints. I figure teams would complain about the cost, and below the front wheel centreline is probably a more aerodynamically sensitive area than above it, so the aerodynamicists would complain about the effect the rule change would have on flow around the strakes and around the floor.
wogx
60
People quickly noticed that Vettel was covered in black dust while doing his media pen interviews too. Rachel Brookes of Sky Sports F1 was quick to ask where it had come from, and it turns out it was from the car’s brake ducts!
“To be honest with you, that is something I think they need to work on because, you know, where the design of the brake ducts this year, the front axle, is blowing all the brake dust into our faces,” Seb reported back.
“It’s not good. Obviously, carbon dust is not really something healthy to breathe in, so I hope the FIA looks into this very soon because it’s pointless and easy to change.”
https://wtf1.com/post/vettel-wants-chan ... brake-dust
chrisc90
37
Did he not have his race suit done up? If suits are to be done up to the collar, I cant see how brake dust will find its way onto his underalls.
mcdenife
mcdenife
chrisc90 wrote:
10 Jul 2022, 23:13
So his nose is below his collar & under his ‘underalls’?
Long experience has taught me this about the status of mankind with regards to matters requiring thought. The less people know and understand about them, the more positively they attempt to argue concerning them; while on the other hand, to know and understand a multitude of things renders men cautious in passing judgement upon anything new. - Galileo..
The noblest of dogs is the hot dog. It feeds the hand that bites it.
chrisc90
37
mcdenife wrote:
10 Jul 2022, 23:59
chrisc90 wrote:
10 Jul 2022, 23:13
How do you explain the black down from his neck to the Sentinal logo?
chrisc90 wrote:
10 Jul 2022, 23:13
The race suit isn't hermetically sealed so it's to be expected that dust with a very small particle size might find its way in through a velcro closure.
Somewhat surprising that the issue of brake dust wasn't considered when they moved to mandate inboard brake venting.
As Seb says, breathing in the brake dust will not be beneficial to drivers' health so it should probably be looked at to see if it can be improved.
mcdenife
mcdenife
chrisc90 wrote:
11 Jul 2022, 00:24
mcdenife wrote:
10 Jul 2022, 23:59
chrisc90 wrote:
10 Jul 2022, 23:13
How exactly does his race suit prevent him breathing in carbon brake dust?
Andres125sx
Wow didn´t know. Carbon dust is extremelly toxic, both for the eyes and lungs. Something to be adressed
Stu
Getting off topic here, but if it has been a ‘thing’ since carbon/carbon brakes were introduced (across the whole grid) it is nothing new - although that doesn’t mean that it shouldn’t be addressed.
Going way back (to the 50’s) the Vanwall exhausted it’s front brakes through the cockpit (check out pictures of Stirling Moss in period).
The answer is front axle ‘harvesting’ - which would make physical brakes almost redundant (really only required in pit stops).
The blackness isn’t just brake dust though…
621
Stu wrote:
12 Jul 2022, 08:55
the rear brakes (because they're inboard)
and because the cockpit is the low-pressure zone
people might also look at the W196 Mercedes-Benz and 300 SLR
in F1 mechanical brakes will always be needed at high speed - where brake power approaches 10000 hp
unless all braking is forced to be regenerative for some efficiency-formula purpose
JordanMugen
82
Stu wrote:
12 Jul 2022, 08:55
Would such equipment further increase car weight? :?: [And open the door to all-wheel-drive for that matter...]
I notice fans are already complaining about the weight of 2022 cars even before any further additional equipment is added to the vehicles.
Big Tea
JordanMugen wrote:
27 Jul 2022, 14:02
Stu wrote:
12 Jul 2022, 08:55
More harvesting could lead to smaller battery packs and reduced weight to offset it. It would require a re write of some regs, but as the MGH-H is being dumped, it would be needed anyway.
Stu
Big Tea wrote:
27 Jul 2022, 15:23
JordanMugen wrote:
27 Jul 2022, 14:02
Stu wrote:
12 Jul 2022, 08:55
That was my line of thinking, smaller batteries (or super-capacitor storage), very high C-rating for fast charge and enough longevity to be considered a ‘boost’ that needs to be deployed strategically.
I won’t be sorry to see the MGU-H go, but would like to see these engines run as NA with a good electrical output.
The other option (if front axle harvesting doesn’t make it) could be to utilise a GU-H in the exhaust.
Big Tea
Stu wrote:
27 Jul 2022, 19:05
Big Tea wrote:
27 Jul 2022, 15:23
JordanMugen wrote:
27 Jul 2022, 14:02
I doubt they would allow that, the sound is considered dim now, although I find it ideal. A little more 'rip' in it needed maybe, but it is plenty loud enough.
