Red Bull RB18
F1Krof
95
Re: Red Bull RB18
Expecting Red Bull to come with basically flat rear-wing.
Wroom wroom
Re: Red Bull RB18
Spa wing trimmed on Perez's car
Max even has the Spa wing untrimmed on the car
Re: Red Bull RB18
08 Sep 2022, 10:57
Presumably they'll run them back to back on Friday to see which gives the best lap time / tyre deg compromise. It's not unusual and the extra wing means more speed through the Lesmos and the fast Ascari chicane can be enough to hold off a lower drag set up. And with the RB18 already being quick in a straight line, that could well be a winning set up.
gandharva
gandharva
252
Re: Red Bull RB18
Or Checo will take a bunch of new components this weekend and they trim his car to low downforce, while Max is running a optimized lap time setup.
Re: Red Bull RB18
Yes would not surprise me if Checo has to cut through the field after taking engine penalties, especially with damaged 3rd engine at Zandvoort
marcel171281
marcel171281
30
Re: Red Bull RB18
08 Sep 2022, 11:32
Which I wouldn't understand. It is the same DRS flap (only trimmed), so with DRS open it doesn't make any difference in top speed. I would rather have more DF to have an higher entry speed onto the straights coming out of corner and also better ability to follow.
TimW
TimW
36
Re: Red Bull RB18
marcel171281 wrote:
08 Sep 2022, 12:41
08 Sep 2022, 11:32
Agree. Only when defending the trimmed DRS flap makes sense, when attacking the non-trimmed version makes more sense (assuming similar laptime when not using DRS)
Re: Red Bull RB18
Max's wing does 340km/h when the DRS is open. It doesn't get much quicker than that for these cars.
The sims are probably telling them Max's wing is the quicker one in qualifying, which is why they are bothering at all.
Re: Red Bull RB18
08 Sep 2022, 15:54
If you can have competitive top speed and some good downforce too, then that's a no brainer for them. It's worked in the past.
napoleon1981
napoleon1981
Re: Red Bull RB18
I expect them both to end up with the trimmed rear wing by Saturday.
Cs98
Cs98
Re: Red Bull RB18
I want them to use the trimmed wing out of curiosity. Probably don't need it but it will be interesting.
Re: Red Bull RB18
Re: Red Bull RB18
Juzh
161
Re: Red Bull RB18
08 Sep 2022, 15:54
340 kmh is spa wing level.
Re: Red Bull RB18
Juzh wrote:
08 Sep 2022, 23:25
08 Sep 2022, 15:54
Yes. And that is the wing that Max has on his car this weekend.
