2022 - McLaren Formula 1 Team
MrGapes
33
Re: 2022 - McLaren Formula 1 Team
djos wrote:
25 Sep 2022, 01:51
I think the Perez example proves the point myself and a few others have been making, Car’s that a handle in a manner diametrically opposed to a drivers style can really make things difficult. Let’s just hope Oscar can drive around a weak front end!
Do you have any evidence to suggest it has a weaker front end… cause I don’t believe it does
djos
113
I’m basing it on commentary from multiple sources and what we know of Daniel’s driving style.
If the McLaren didn’t have a weak front end, then it stands to reason that the car wouldn't require the brake in a straight line then turn style Lando has been using.
To be fair to McLaren, it has been exacerbated this year by the weaker than expected Pirelli front tires. As a result Pirelli have announced they are working on a grippier front tire for next year.
"In downforce we trust"
Isn't Perez still running and old floor that he doesn't get till Singapore? Perez's floor was the first kick at the new Belgium regs and is flawed. They can't back to previous floors cause legal reasons.
djos
113
diffuser wrote:
25 Sep 2022, 10:25
RedBull reckon that’s worth a 1/10th at most.
Big Tea
djos wrote:
25 Sep 2022, 02:00
When the car is not in a straight line, it is not only the front end that is not directly 'head on' to the flow. Turbulence from anywhere along the whole length could destroy the 'normal' flow, even just the tyres presenting a different angle could disrupt flow all along the car if it was bad enough.
(not saying it isn't the front mind)
Swed3121
Swed3121
Seems this weekend is going to a be real I know for the car.
The car seems to like twisty, slow speed circuits and doesn’t mind bumpy tracks, however it has an aversion to high temperatures and DRS trains.
Will be interesting to see how this one develops.
Any predictions?
Not sure, the new package should add a noticeable chunk of downforce but I think the DRS trains are still going to be an issue.
billamend
billamend
djos wrote:
25 Sep 2022, 02:00
The MCL does not have a weak frontend. What it does have is a characteristic where it lifts the front and understeers when you lift the break/accelerator pedal mid-corner. So you have to mix the accelerator and the breaks at the same time, you can't do one and then the other. Ricciardo is used to break and _then_ accelerate, which doesn't work with the McLaren.
230
billamend wrote:
25 Sep 2022, 22:06
djos wrote:
25 Sep 2022, 02:00
You said it yourself. This is a weak front end from your description.
djos
113
Agreed, Sure sounds like one to me too.
univex
univex
I tend to think this will be another Honda moment for McLaren.
With Honda they stuck doggedly to a design philosophy (minimal side pods) which Honda struggled with (focussed on cooling-reliability instead of performance). They openly ignored Honda requests for design changes.
With RBR, Christian Horner was upfront about giving Honda some design input and building the car around what they required.
Now you have McLaren sticking to a design philosophy (or at least not focussing on a design issue) in the belief that LAN can drive it and they will continue to get faster.
I would have been tempted to develop the car around RIC as he was previously fast in a very fast car.
NOR is faster in the current and previous MCL, however the car still needs to be faster. NOR has not driven a front running car, and you don't know what you don't know.
Yes, I know, this is a simplistic opinion on a much more complicated issue.
bauc
33
univex wrote:
26 Sep 2022, 06:40
RIC was slow in Renault as well. He was only fast at RRB were everything worked in sync with his driving style.
bauc wrote:
26 Sep 2022, 15:07
univex wrote:
26 Sep 2022, 06:40
He was not slow in 2020. That's revisionism
He destroyed Ocon for most of the year (with Ocon only looking like he was actually decent by the end of the season), and team principles rated him as 3rd best driver of the year which seems to agree with the impression I had
Ground Effect
Ground Effect
bauc wrote:
26 Sep 2022, 15:07
univex wrote:
26 Sep 2022, 06:40
Daniel definitely wasn't slow at Renault, that's why McLaren signed him, remember?
Unfortunately we might never know the actual answer, if Pirelli actually delivers next year.
We do know that almost every driver was struggling with understeer and not being able to trail brake when we first went on these tyres, even back in first testing. I don't think he'd have been happy with any car this year.
