F1TV
gandharva
gandharva
252
Re: F1TV
Multiviewer is the way to go. There is also a nice Tampermonkey script for the lazy people: https://github.com/najdek/f1tv_plus
chrisc90
Re: F1TV
gandharva wrote:
30 Sep 2022, 12:31
Just downloaded that. Well good.
Is there any downloadable layouts you can get that you know of?
A.J.O
A.J.O
Re: F1TV
Juzh wrote:
30 Sep 2022, 10:17
Just install (unzip) this:
https://beta.f1mv.com/
enter your f1tv creds and you're good to go.
This is fantastic! Thanks for sharing
chrisc90
Re: F1TV
I presume that Multiviewer works with the live stuff aswell. I did see some DRM restrictions somewhere. Would be epic if it did work live.
Juzh
161
Re: F1TV
chrisc90 wrote:
30 Sep 2022, 22:37
it works with live.
gandharva
gandharva
252
Re: F1TV
chrisc90 wrote:
30 Sep 2022, 20:41
gandharva wrote:
30 Sep 2022, 12:31
I don't understand your question. You choose Popout or Multi-View and then select the desired layout based on the aspect ratio of your monitor. Syncing is then done automatically between all open windows and works even better out of the box than in Multiviewer.
Syncing imho is the biggest minus on Multiviewer, as it is broken very often, and then you need to manually adjust which is annoying.
chrisc90
Re: F1TV
gandharva wrote:
01 Oct 2022, 11:05
chrisc90 wrote:
30 Sep 2022, 20:41
gandharva wrote:
30 Sep 2022, 12:31
A bit like a template. It looks the layout is saved in a file so it would be possible for others to share their file of layout, of say live feed, driver cams, tracking, timing etc and someone else can use that file to add that template to their device.
gandharva
gandharva
252
Re: F1TV
Ah, now I got it. I don't think saving layouts in that way is implemented into this script.
tpe
tpe
-4
Re: F1TV
I revive this thread because honestly I am confused.
If I understand correctly¸ the difference between the TV Pro and TV Access is that the latter doesn't stream all the sessions but it does stream the race and that the radio is not live.
Correct?
Juzh
161
Re: F1TV
tpe wrote:
04 Mar 2023, 17:26
Correct?
Access doesn't have live sessions, any of them. That's the main difference. Delay is usually 2 days, but it depends on country.
tpe
tpe
-4
Re: F1TV
OK, so it's useless basically. Thank you!
zeph
zeph
Re: F1TV
These days F1TV is all good for me, the teething problems have all been addressed and it's been solid. Even the UI on Roku and in the browser is better now. Still not great, but better.
My main beef is the inherent delay, sometimes it can be as much as few seconds behind the TV/Satellite stream.
Re: F1TV
The commentary with Coulthard/Alex Jacques and palmer was elite today
Sky commentary has become lazy thinking they're the default product of F1 broadcasting
tok-tokkie
tok-tokkie
38
Re: F1TV
I could not get F1TV to stream during qualifying yesterday until I changed browser from Brave to Chrome.
hollus
Re: F1TV
The delay can hardly be avoided in an stream, can it. Does any streaming service not have it?
TANSTAAFL
