Alpine A523
hollus
Alpine A523
Thunder wrote:
05 Feb 2022, 12:25
https://i.imgur.com/R86vIUw.png
This is the official Alpine A523 car thread. The thread has been created to facilitate discussion specifically about the A523 car.
Livery discussion also belongs in the 2023 Alpine F1 Team thread.
Rivals, not enemies.
gandharva
252
Re: Alpine A523
chrstphrln
Re: Alpine A523
Wow. That is not a good looking car...
Henk_v
78
Re: Alpine A523
The car looks like seperate teams worked on different parts of the car.
It looks like an old woman in a robe.
SmallSoldier
473
Re: Alpine A523
Credit?
On another note, interesting profile of the End Plates:
From the above pictures
Re: Alpine A523
SmallSoldier wrote:
14 Feb 2023, 20:02
Credit?
https://i.imgur.com/V1aD3NX.jpg
Someone shamelessly removed the photographers signature from the photo :lol:
At least rewrite his name at one corner
The endplate is the same design as last year ; )
viewtopic.php?t=30842&start=60
continuum16
49
Contact:
Re: Alpine A523
You can see from the side-on shot that they have cooling louvers on the back of the engine cover centerline like Haas and Red Bull ran last year, despite having no shark fin.
I wonder if they moved the cockpit rearwards in order to give themselves more distance between the tunnel entrances and the front axle, causing them to push everything behind it backwards, and that's why they don't have a shark fin.
- Mark Twain
SmallSoldier
473
Re: Alpine A523
Blackout wrote:
14 Feb 2023, 20:17
SmallSoldier wrote:
14 Feb 2023, 20:02
Credit?
I never noticed! Thanks!
Re: Alpine A523
A different angle. I wonder if they opted to increase the width of the nose to put more front downforce, instead of increasing the size of the front wing. The latter still looks like the smallest FW.
Is there a maximum volume for the nose?
Mattchu
49
Re: Alpine A523
Looks like some sort of cooling ducts on the shark fin area, ala Mercedes did a while back although not as extreme...
Image taken from above.
Re: Alpine A523
continuum16 wrote:
14 Feb 2023, 20:20
Those rear outlets got more prominent indeed. And maybe they are filling what remains of the shark fin volume.
AMuS 2022
Regarding the cockpit position, that's what I was speculating in the other thread.
JPower
43
Re: Alpine A523
At the very least, I think Alpine's aero team proved themselves to be pretty solid. Not too much visual difference I can spot from the above photos which shows confidence in their concept.
If they can reliably wring more performance out of the PU, they should be up at the front of the midfield again.
Re: Alpine A523
The water slides seem to start earlier too
The water slide looks a bit smoother here. Less bumpy around the exhausts area...
dren
226
Re: Alpine A523
Looks like the upper rear wishbones are dropped on the chassis connections a bit.
Honda!
xReVo
Re: Alpine A523
probably the front and the rear wing will be different in testing, like other teams.
