Alpine A523
Goblin42
53
Re: Alpine A523
Re: Alpine A523
Many interesting small details here, like the little notches on the top edges of the nose. The aim might be to let air escape sideways & prevent it from producing too much lift (anti-DF) in that area where lift is inevitable. (red arrows)
Nice downwashing cannons. The A522B was straight
CFD pic: viewtopic.php?t=28657
Re: Alpine A523
This also shows how the engine/rollhoop cover got slimmer.
Re: Alpine A523
What are the main advantages for their change in nose and fw main plane design? Like they've gone towards the early Aston Martin '22 approach
Re: Alpine A523
20 Feb 2023, 19:12
My theory viewtopic.php?p=1112945#p1112945
Re: Alpine A523
Blackout wrote:
20 Feb 2023, 19:14
20 Feb 2023, 19:12
That all makes sense to me. I guess my thinking is why swap to that in year 2? Especially with tyres arriving that will reward more front df
Are they swapping to this because they've found a very powerful floor solution that they want to exploit to the max? Or is it possible because of the new front suspension approach? Or the more modular nose/front wing lets them take this risk
Or just a combination of these factors
This probably isn't answerable without inside info into the team. It's just what I've been toiling with recently with so many teams changing their nose/fw concept in the 2nd year which I didn't expect at all
Re: Alpine A523
The optimistic me would say they found an FW/nose combination that produces a lot of DF (which si good for the new tires indeed) and tried to raise it, but it still produced a lot of DF, so they retained the raised version because it is good for the rest of the car : )
Re: Alpine A523
Blackout wrote:
20 Feb 2023, 19:35
Now give us the realistic version :wink:
Re: Alpine A523
I've thought about rake, but I don't think they've set this up for running some rake in slower corners? Does look like it can stuff more air underneath in fast corners, then in slow corners with rake, give more front end and help pivoting the car?
Re: Alpine A523
We'll see
20 Feb 2023, 19:44
Blackout wrote:
20 Feb 2023, 19:35
I just have a pessimistic version that is not realistic : P
The floor leading edge matches the render. The more curvy new edge is lower inboard... But the mouth volume might be a bit bigger...
Re: Alpine A523
Re: Alpine A523
Re: Alpine A523
Thanks.
Boat-tail shape and diffuser kick look different.
A523 has lower sidepods than A522, so that rib/ridge/dip looks more extreme.
But I think the top side impact structure, A.K.A S.I.S or SIPS remained at a similar height as 2022
Re: Alpine A523
Tobi Gruner 📸
Alpine keel
Re: Alpine A523
Is it me or there is a secondary dip, inboard, 'under the BP Ultimate' ?
https://twitter.com/paddock_inside
Sadly the angles are not the same. The A522 front wheel is closer to the camera...
So we must wait for better pics*
There is an interestin flick-up on RW endplate
📸Nextgen-Auto /RaceFans
