Haas VF-23
Re: Haas VF-23
Haas might have an S-duct?
Beware of T-Rex
Re: Haas VF-23
22 Feb 2023, 18:50
Any photos of a potential outlet or inlet?
Re: Haas VF-23
22 Feb 2023, 18:53
22 Feb 2023, 18:50
I could just be seeing things. Post updated at my guess.
Beware of T-Rex
Re: Haas VF-23
22 Feb 2023, 18:54
22 Feb 2023, 18:53
22 Feb 2023, 18:50
https://i.postimg.cc/R0YvYt7j/image.png
Ooh yeh could be that
Re: Haas VF-23
22 Feb 2023, 18:55
22 Feb 2023, 18:54
22 Feb 2023, 18:53
Yeah it looks like it could be covered by a blanking panel for now, and to open it at the test.
The reason I suspect them is because they are working in Maranello and well...engineers have espresso.
Beware of T-Rex
Re: Haas VF-23
Edit: Upon closer inspection, I'm not sure I see what I think I see so it's probably straw clutching at best. However, given the similarity conceptually between the Haas and the Ferrari, it's hard to see Haas not integrating one if they have not already.
Beware of T-Rex
Cs98
Cs98
Re: Haas VF-23
22 Feb 2023, 19:01
It would probably cause a bit too much of a stir if Haas show up with an S-duct. It's not the sort of thing I imagine Ferrari would share, and the chances they arrived there by coincidence are astronomically low. Doubt it's them.
gordonthegun
261
Re: Haas VF-23
Haas has last year Ferrari sidepods and the s-duct wasn't designed on those.
continuum16
52
Re: Haas VF-23
Most likely not S-duct related, but they have brought new (presumably higher-cooling) bodywork to Bahrain, they just did a second shakedown before the test and posted a video on Twitter (as you can guess by the horrendous compression).
As you can see, they have a giant slot that goes all the way from the halo height and blends into the regular louvres on the sidepods. Very elegant. Weird that there are only two slots (highlighted in yellow), but perhaps this is adjustable based on demand.
On a slightly more tinfoil-hat note, they also posted a bunch of pictures with dialed-up contrast which conveniently hide the front of the sidepod and floor entry where any S-duct inlet could be located. And these new slots (the front one at least) could very well be hiding an outlet.
I agree with the above statement that it would cause a stir for them to turn up with one since Ferrari did, but any alleged flow of information presumably goes both ways. Who’s to say someone at Haas didn’t think of it first? Hypothetically speaking, of course.
- Mark Twain
Re: Haas VF-23
No s-duct visible here but might not want to show it off so blatantly
Henk_v
Henk_v
89
Re: Haas VF-23
Look at the last picture, inside the sidepod inlet, below the mirror (in this view). I think i see a dividing structure that intersects the bottom radius. If it was somewhere, it's there.
Re: Haas VF-23
Credit: BladeOfJae
Vertical outlet behind the cockpit that was not visible on the car this morning. It's possible they have a removable panel here.
From behind:
With the previously noted divider in the sidepod inlet, it seems quite possible this is one of the other rumoured s-ducts
Re: Haas VF-23
Looking at not the new winglet on the inboard side of the endplate. Look at the diveplane.. seems interesting the way it joins to the endplate
SmallSoldier
SmallSoldier
488
Re: Haas VF-23
Vía: AMUS
Re: Haas VF-23
Haas are the kings of cost-cutting :mrgreen:
