Alpine A523
SmallSoldier
473
Re: Alpine A523
Vía: AMUS
SmallSoldier
473
Re: Alpine A523
Front suspension panel removed:
Vía: Sala Stampa
Re: Alpine A523
A nice pic thx to Piola. It also shows the new suspension, especially the more neatly integrated '23 anti-roll tubes that help making the car rear end tighter.
But dont read F. Nugnes analysis & infos.
He looks like a noob, despite the fact he's been around for 180 years.
Re: Alpine A523
A nice view on the new front susp geometry.
The other important change compared to '22 is that the floor leading edge connects to the bib underneath the nose, like the earlier RB '22 floor, not the nose.
& the engine cover screws location are a clue about the next update.
Or not.
Re: Alpine A523
Winter 2022 / Winter 2023
SmallSoldier
473
Re: Alpine A523
Posted this pic earlier”
I’m curious about the gear in the gear in the damper, any ideas?
SmallSoldier
473
Re: Alpine A523
Low DF Rear Wing for Alpine in the last day of testing…
Re: Alpine A523
I dont know what that suspension element is. Maybe a rotative adjuster for the springs?
The '23 centerline cooling size decrease is probably due to a better angle too. It's facing the air so it can be smaller.
Smaller rads → slimmer ducts & less air needed → slimmer rollhoop → more air for rear wing* & less drag → more downofrce → 23 triple podiums for Alpine.
*or the same amount of DF but with less lift produced by the less wide and sloping rollhoop cover
Do this cooler raise CoG? not necessarily, & A523 has 3000kg of ballast so it can offset that.
& even if it raises CoG, aero gains are probably 5 times worth the car dynamics loss
But Harman said the new system is more efficient too
Re: Alpine A523
Re: Alpine A523
The very new RW. Maybe it replaces the A522B medium DF RW (below - Suzuka)
Re: Alpine A523
The old alpine nose looks so ugly compared to this car.
They will use the new rear-wing at somewhere like Miami?
Re: Alpine A523
25 Feb 2023, 11:40
And sensors inside tunnel entries
Re: Alpine A523
25 Feb 2023, 13:14
Last year in Miami they used the lower DF RW (& they used it in Jedda)
Re: Alpine A523
@JoostNederpelt
Re: Alpine A523
It seems they added an extension to the boat tail, A.K.A keel, similar to what Ferrai did last year...
Ferrari: (Motorsport / Piola)
