vorticism
vorticism
449
"Side of the gearbox" is vague; the casing or the cassette? No screws on these driveshafts afaik and the closest nearto might be a boot fastener leading to a loss of lubrication in the CV joint. Assuming the article referenced in this tweet even exists, and if it does, it even be accurate. Bearing or assembly failure is more serious, I think they'd be overhauling or replacing the unit and not just swapping in a new driveshaft.
Perez has bahrain rear wing and single element beam wing.
#ReleasetheADUO
01 Apr 2023, 04:33
Very interesting. Thank you for finding that
So far this year they have only shown two beam wing configs
lio007
327
01 Apr 2023, 05:35
01 Apr 2023, 04:33
Except for Jeddah.
lio007 wrote:
01 Apr 2023, 06:54
01 Apr 2023, 05:35
01 Apr 2023, 04:33
Except for Jeddah.
They used the high df spec at Bahrain and the low downforce single element at Jeddah and now Australia. Only 2 different beam-wings.
lio007
327
01 Apr 2023, 06:55
lio007 wrote:
01 Apr 2023, 06:54
01 Apr 2023, 05:35
Except for Jeddah.
Sorry, misread your post. Too early in the morning :)
Perez just got the floor exposed :lol:
#ReleasetheADUO
BlueCheetah66
BlueCheetah66
33
There better be some cameras around that RB19
The reliability is woeful and the tire strategy in Q3 was dire.
#ReleasetheADUO
langedweil
Great lap by Max, Mb well done, Alb just 0.2 behind Lec ..
HuggaWugga !
mendis
mendis
19
01 Apr 2023, 08:04
Not the best of the weekends for Red Bull with everything looking below par. The tire strategy was definitely a mess, considering the whole field was doing 2 warm up laps, there was no reason for Max to go with just one.
BlueCheetah66
BlueCheetah66
33
Convinced if they had done the double build lap they could have gained a tenth or two. Hopefully the reliability is fine for tommorow
BlueCheetah66 wrote:
01 Apr 2023, 08:28
With the bad downshifts, would they have even been able to use full power?
#ReleasetheADUO
Repost....Chocolate car confirmed.
I checked the telemetry and Max definitely did not have full power on his last run. I compared an early run from Q1 (blue line) to his Q3 lap (white line) and you can see that he lost power in Q3. Down 3-4km/h on the main straight, and down 3-4 km/h on the run to Turn 9, and the run to T11. :?
#ReleasetheADUO
avantman
avantman
delete
