I almost suspect you of trolling right now. It's very clear to me on the pictures posted that Verstappen is running less front wing than Perez. It's easily visible.marcel171281 wrote:If anything, this picture shows Verstappen has the more loaded front wing. Assuming the part connected to the nose cose is identical, you can see the flap on Verstappens car is higer relative to that than the flap on Perez' car.
But different angles, different speeds.
Are a couple of clicks extra on the FW visible on random pictures? I doubt it very much.
Well, I fully agree with Marcel. Look at the COTA pictures, right side of the wing(left for the viewer). For Perez, the adjustable part of the top flap forms a continuous line with the fixed inner part near the nose. For Verstappen, the adjustable part clearly stands higher than the fixed part. So that would be more front flap angle for Max.TFSA wrote: ↑23 Oct 2023, 06:32I almost suspect you of trolling right now. It's very clear to me on the pictures posted that Verstappen is running less front wing than Perez. It's easily visible.marcel171281 wrote:If anything, this picture shows Verstappen has the more loaded front wing. Assuming the part connected to the nose cose is identical, you can see the flap on Verstappens car is higer relative to that than the flap on Perez' car.
Which fits in with what we know about both drivers preferences - Max likes a pointy front end, Checo much less so.TimW wrote: ↑23 Oct 2023, 07:00Well, I fully agree with Marcel. Look at the COTA pictures, right side of the wing(left for the viewer). For Perez, the adjustable part of the top flap forms a continuous line with the fixed inner part near the nose. For Verstappen, the adjustable part clearly stands higher than the fixed part. So that would be more front flap angle for Max.TFSA wrote: ↑23 Oct 2023, 06:32I almost suspect you of trolling right now. It's very clear to me on the pictures posted that Verstappen is running less front wing than Perez. It's easily visible.marcel171281 wrote:If anything, this picture shows Verstappen has the more loaded front wing. Assuming the part connected to the nose cose is identical, you can see the flap on Verstappens car is higer relative to that than the flap on Perez' car.
Sure, but did those reports only look at the front wing angles? F1 Cars have rear wings too, at least last time I checked.organic wrote: ↑23 Oct 2023, 07:15Right but two top of the line trackside journalists are reporting otherwise and in my opinion the pictures back up their testimony. Duchessa reported at Qatar that RB arrived with base setups with Checo using more front wing than max. Mark Hughes talks about Max running less wing at COTA then Checo
With the current generation of the rear wings, you can't change the rear wing flap angle for a given assembly. It's why rear wing design is so critical in this new regulation era. Lack of discontinuous endplate/plane connection means you can't just change the wing angle with the same RW assemblydjos wrote: ↑23 Oct 2023, 07:18Sure, but did those reports only look at the front wing angles? F1 Cars have rear wings too, at least last time I checked.organic wrote: ↑23 Oct 2023, 07:15Right but two top of the line trackside journalists are reporting otherwise and in my opinion the pictures back up their testimony. Duchessa reported at Qatar that RB arrived with base setups with Checo using more front wing than max. Mark Hughes talks about Max running less wing at COTA then Checo![]()
Good point - however, those are 2 different spec front wings, not just different angles. I'd tell you which makes more DF, but my EyeBall-CFD module was never installed.organic wrote: ↑23 Oct 2023, 07:23With the current generation of the rear wings, you can't change the rear wing flap angle for a given assembly. It's why rear wing design is so critical in this new regulation era. Lack of discontinuous endplate/plane connection means you can't just change the wing angle with the same RW assemblydjos wrote: ↑23 Oct 2023, 07:18Sure, but did those reports only look at the front wing angles? F1 Cars have rear wings too, at least last time I checked.organic wrote: ↑23 Oct 2023, 07:15Right but two top of the line trackside journalists are reporting otherwise and in my opinion the pictures back up their testimony. Duchessa reported at Qatar that RB arrived with base setups with Checo using more front wing than max. Mark Hughes talks about Max running less wing at COTA then Checo![]()
Also here are two front wings. Images taken by the same photographer from the same place observing the cars at the same corner at the same point of turn-in. Which car is running more front wing?
https://i.imgur.com/HDCX26a.jpeg
https://i.imgur.com/GNk5wxN.jpeg
Yes I agree that the flap configurations are not the same. However we know that RB only have 2 used flap configurations. It launched at Bahrain with only the low-medium downforce wing available. The medium-high front wing config was brought @ Australia much to the relief of Verstappen. He was complaining about the lack of this wing at Bahrain over the radio in subtle ways to GP all weekend.djos wrote: ↑23 Oct 2023, 07:28Good point - however, those are 2 different spec front wings, not just different angles. I'd tell you which makes more DF, but my EyeBall-CFD module was never installed.organic wrote: ↑23 Oct 2023, 07:23With the current generation of the rear wings, you can't change the rear wing flap angle for a given assembly. It's why rear wing design is so critical in this new regulation era. Lack of discontinuous endplate/plane connection means you can't just change the wing angle with the same RW assembly
https://i.imgur.com/GNk5wxN.jpeg![]()
