2023 Las Vegas Grand Prix - Las Vegas, Nov 16 - 18
the EDGE
the EDGE
68
Re: Las Vegas 2023
Pirelli have the option to lower tyre pressures for this event if it feels it’s safe to do so, this will help with tyre warm up, it just depends on other track factors such as kerbs, that could cause damage
bluechris
Re: Las Vegas 2023
the EDGE wrote:
11 Nov 2023, 18:04
I think you need to raise the pressure to get more heat. At least that is what is happening with my car & motorcycle :)
the EDGE
the EDGE
68
Re: Las Vegas 2023
bluechris wrote:
11 Nov 2023, 18:53
the EDGE wrote:
11 Nov 2023, 18:04
No, tyre deformation will increase with less pressure and create more heat through the increased flexing of the rubber
Re: Las Vegas 2023
Farnborough
Farnborough
152
Re: Las Vegas 2023
the EDGE wrote:
11 Nov 2023, 19:16
bluechris wrote:
11 Nov 2023, 18:53
the EDGE wrote:
11 Nov 2023, 18:04
Absolutely correct, lower pressure allows more carcass flex under the same load to generate more heat.
Tyre manufacturer (all of them for all uses) put minimum pressure recommendations to avoid that heat build up taking the tyre into failure from delamination ultimately as it starts to unbond the structural elements.
It is a tool available but there's care needed in this type of circuit from sustained longitudinal flexing (similar to Baku and that tyre failure MV had) under maximum load and high period of centrifugal extension down the long straights.
Looks like its going to be a delicate balance for all, possibly with some odd chassis characteristics shuffling the order of pace that's normally seen.
LM10
LM10
127
Re: Las Vegas 2023
bluechris wrote:
11 Nov 2023, 18:53
the EDGE wrote:
11 Nov 2023, 18:04
What you see there is raising pressure with raising heat due to energy being put into the tyres while driving.
Sempre Forza Ferrari
bluechris
Re: Las Vegas 2023
LM10 wrote:
11 Nov 2023, 20:12
bluechris wrote:
11 Nov 2023, 18:53
the EDGE wrote:
11 Nov 2023, 18:04
I see this during track days where i put my car in and i end up lowering tyre pressures because my tyres overheat after some push laps (normal tyres, not slicks) but i understand what you & others are saying.
Mogster
Re: Las Vegas 2023
Maybe I’m missing something but why are the local timings so weird? FP2 and Qu at midnight? Isn’t that going to piss off the Vegas residents royally?
39
Re: Las Vegas 2023
Mogster wrote:
11 Nov 2023, 21:23
Vegas requested that as to have less impact on the strip. One of the lines I read was along the lines of "People come to Vegas to have dinner and then see a show."
And if you go back and look at the link that was posted for another forum, many of the residents are already pissed with all the traffic disruptions and stuff going on.
Mogster
Re: Las Vegas 2023
1158 wrote:
11 Nov 2023, 21:27
Mogster wrote:
11 Nov 2023, 21:23
Fair enough. It does seem to be inline with other pay to view sports events like boxing. Those are inside though…
chrisc90
Re: Las Vegas 2023
Do they actually plan to 'open' the strip between F1 sessions? so the public can drive on the track?
Re: Las Vegas 2023
chrisc90 wrote:
11 Nov 2023, 21:30
"For the Las Vegas GP to take place, major streets must be closed off starting around 5 p.m. on Thursday, Friday and Saturday.
They must then be reopened to traffic by 4 a.m. each day."
When the streets are closed starting around 5 p.m. why starting FP1 and FP3 so late?
18 Nov
Race
22:00
18 Nov
Qualifying
00:00 - 01:00
17 Nov
Practice 3
20:30 - 21:30
17 Nov
Practice 2
00:00 - 01:00
16 Nov
Practice 1
20:30 - 21:30
Farnborough
Farnborough
152
Re: Las Vegas 2023
bluechris wrote:
11 Nov 2023, 21:20
LM10 wrote:
11 Nov 2023, 20:12
bluechris wrote:
11 Nov 2023, 18:53
You bring up an interesting aspect there that is common to F1 in that a road tyre and a "hard" compound race tyre display similar characteristics. Too high a pressure, then the carcass doesn't flex to contribute in warming the structure, the tread though slides causing too much heat in that tread depth, the tyre then shows less grip to the driver, but now lacks that pure traction to effectively bend the carcass and establish its normal method of generating heat. You can see this is a circle response that's hard to get out of as in a race they simply need pace and can't back out of that without getting caught.
Exactly what we see on different chassis and how they work the different tyre compounds, with some able to use all the tyre types, others just effective on one type and very poor with alternatives. All the more heightened by the change in 13" to 18" in F1 these are simply narrowed in their "gateway" of peak performance, without the ability to stay right in that zone the performance is toast :D
Otromundo
Re: Las Vegas 2023
If the race is not suspended and the Aston Martins go well... I'm betting on Fernando. I think it will be his best opportunity to shine and even win in this season. The worse the weather, the better for him.
Believe half of what you see and none of what you hear.
Re: Las Vegas 2023
Otromundo wrote:
11 Nov 2023, 22:25
His best opportunity was Monaco and the team messed up by not taking intermediate tyres. With one different decision they'd have won the race. They've not had race winning pace for over 10 rounds now so I wouldn't be confident in saying they'll compete for a podium here, even with a possible mixed up order
