Ferrari SF-24
Re: Ferrari SF-24
deadhead wrote:
20 Mar 2024, 21:34
Can someone please point to where the gearbox sits exactly?
It's right in the middle of diffuser ramp :)
Vanja #66 wrote:
09 Mar 2024, 18:08
yellow is pressure recovery around the gearbox case
Speaking of gearbox, there's an article about it (and rear suspension) and an illustration from Piola. Disclaimer - Not sure if he has a photo and did his usual detailed overlay or if this is an illustration based on other SF24 photos and SF23 gearbox.
https://www.motorsport.com/f1/news/why- ... /10589033/
Andi76
Andi76
398
Re: Ferrari SF-24
deadhead wrote:
20 Mar 2024, 21:34
Andi76 wrote:
20 Mar 2024, 21:23
https://postimages.org/
Not quite true to scale and the final drive goes two millimeter further back and then you have the rear crash structure:
Re: Ferrari SF-24
jambuka
jambuka
25
Re: Ferrari SF-24
SF-24 Melbourne GP 2024
Stu
Re: Ferrari SF-24
Nice to see them going with the ‘hiding in plain sight’ outwash encouraging small/short FW endplate idea from the RB19.
There is some very nice detailing on the car this year.
Re: Ferrari SF-24
Best view of the floor inlet so far. Very subtle changes compared to SF23 Japan floor, there could be a bigger change coming in Imola.
SF23 (Qatar?)
Farnborough
Farnborough
91
Re: Ferrari SF-24
Very interesting images there.
It appears, to me, that the outer three routes of underfloor are relatively crude in just getting as much volume out the side of chassis to remove from flow underneath into venturi, consequently they're maybe less sensitive to shape, form etc.
The first "strake" next to the monocoque "hull" front end, would appear to hold much more intricacies in its overall effect, it's relative balanced volume against rear diffuser performance, also the parity of flow distribution to each side when presented to yaw approaches, then to differential negative pressure from one side in contrast to the other.
There's quite a bit of thinking and shift in these two strake noted above from each of the teams, clear importance of performance and understanding seems fundamental to overall effect, more so than some of the other elements.
Stu
Re: Ferrari SF-24
I think that the most successful floors are using the outer strake to manage tyre wake (and keep it out of the underfloor); the outer pair of underfloor channels to create a longitudinal Venturi throat (thereby promoting a forward biased CoP at lower speeds - before the rear suspension has dropped under load). This allows for a rearward biased ‘main’ Venturi throat into the diffuser which moves the CoP rearwards as speed increases.
The front floor edge is being turned into a wing profile. The inside strake can be trimmed to suit the required aero map on a track specific basis.
Emag
Emag
75
Re: Ferrari SF-24
jambuka wrote:
21 Mar 2024, 07:46
https://pbs.twimg.com/media/GJKj940a4AA0s1M?format=jpg
I guess it has been mentioned before, but Ferrari has the tightest centerline of all of them (I believe). They first tried this back in 2019, but I guess they keep seeing gains in having wider sidepods as a compromise for the thinner airbox. Which coincidentally works out nicely for this regulation set since the "wide & downwashing" is kind of the way to go when it comes to sidepods.
It seems to be the "logical" way to go. But then you got RedBull using the centerline for Newey knows reasons. And it's not like they thinned the sidepods either. Compared to the previous iteration of cars, where tight bodywork was usually the way to go and it was seen as a measure of competitiveness, this is now no longer the case and the surface aero gains from bulky bodies outweigh the compromises.
But I guess Ferrari already proved this in 2022 with the bathtub sidepods.
venkyhere
venkyhere
Re: Ferrari SF-24
Emag wrote:
21 Mar 2024, 11:43
Until this floor venturi regulations arrived, keeping away front wheel wake could be relegated to bargeboards, and shrink wrapping the body gave frontal area benefits (the reason I attribute to 2020 cars being the fastest ones over the past decade). Not the case anymore.
Re: Ferrari SF-24
Winglet added to RW pylon. Small upgrade was accurate
Image from formu1a uno https://formu1a.uno/novita-ferrari-ce-u ... osteriore/
DoctorRadio
DoctorRadio
Re: Ferrari SF-24
21 Mar 2024, 16:01
https://i.imgur.com/XdzIQTU.jpeg
Those guys are rarely wrong 👍🏼
FDD
FDD
68
Re: Ferrari SF-24
One more pic of the aero appendix
Vinlarr89
Vinlarr89
Re: Ferrari SF-24
Any ideas what the purpose of this winglet is. Is it there as a flow conditioner of some sort?
KimiRai
KimiRai
216
Re: Ferrari SF-24
