Red Bull RB21
Paa
Re: Red Bull RB21
Are there any pics/video regarding wing flex?
How does it compare to other top teams?
Re: Red Bull RB21
venkyhere wrote:
15 Mar 2025, 17:59
which of the two floors used in Bahrain is in the car for the Aus GP ? the v1 floor or the v2 floor (that was tested and then rejected within one test session) ?
V2 for max all weekend
Paa
Re: Red Bull RB21
17 Mar 2025, 00:49
venkyhere wrote:
15 Mar 2025, 17:59
Max looked quite comfortable in the car all weekend unlike to the 3rd day of test, which means that they must have found something in the simulator to make the v2 floor work.
They also must have found something from Friday to Saturday to make it faster.
Looks like a fast learning curve (or slow start with the new floor, depending on how you phrase it).
venkyhere
Re: Red Bull RB21
Thanks guys, so looks like the v2 floor with the new front wing is indeed working well. Comparing to the Q3 time for RB20, RB21 is ~0.5s faster. That bodes well. And it seems to me that with Max at the helm, RB21 can 'match-up' to MCL39 when the tyres are relatively fresh. The 'tell' that this is indeed the case was the behaviour of the car in sector1 and T9-T10 in Australia. Car does seem to have good traction out of slow corners and is able to handle sudden opposite load shifts laterally, without understeering. Tyre wear is the biggest elephant in the room now (as it was in 2024 as well), because I think the problem with rotation in slow turns is solved (from eyeballing, I admit). Kerb riding is the other issue , which remains to be seen on tracks with big kerbs.
Brahmal
Brahmal
Re: Red Bull RB21
f1isgood
f1isgood
Re: Red Bull RB21
venkyhere wrote:
17 Mar 2025, 08:05
I think 2024 had good tire wear if the tires were in the right window. This car seems to be in the right window.
I think this is a potentially simpler problem to solve (maybe add some downforce?) and that should help already. The car last year had the most downforce of any car and still struggled to keep the tires in a working window.
Call a spade, a spade.
Andi76
Andi76
449
Re: Red Bull RB21
Re: Red Bull RB21
Andi76 wrote:
25 Mar 2025, 19:51
https://postimages.org/
Lawson has the old parts (maybe gave him more confidence)
Lasssept
66
Re: Red Bull RB21
Farnborough
Farnborough
124
Re: Red Bull RB21
Interesting image, looks like a bare tub (presumably the spare) as no substantial suspension hardware etc is installed.
Detail of that vertical sector air intake of sidepod quite intricate, going down deeper than can be clearly seen with floor etc in place.
Lasssept
66
Re: Red Bull RB21
Luscion
Luscion
117
Re: Red Bull RB21
Upgrades for Japanese GP
Re: Red Bull RB21
are these rear brake cake tins new?
Pretty in the sun
Re: Red Bull RB21
The rear brake tin looks 3D printed. Those parts were made in a hurry.
Silent Storm
Silent Storm
130
Re: Red Bull RB21
04 Apr 2025, 04:26
Different material for less or more heat transfer? GP told Max to try a different "test cycle on braking" so they are looking at either getting rears upto temperature or not overheat.
