SB15 wrote: ↑19 May 2025, 16:24
Space-heat wrote: ↑19 May 2025, 12:27
SB15 wrote: ↑19 May 2025, 12:13
No it’s the repositioning of the wishbones they did with the rear suspension this weekend. They did not have this much rear tyre overheating until they made this change. I think they did it to improve high-speed cornering, which Fdataanalysis on Twitter shown that the car was very good in, but we should all know that less give (stiffness) on the suspension promotes more tyre heat because how much strain the tyres are in vs softer setups.
But this weekend showed something that is very clear to me.
So what’s my theory?
Well, I remember seeing the rain aero flow and with the RB19. I can now see why RBR made their sidepods as wide as possible and uniquely design their Venturi exits on the floor edge to make sure the air wake goes around the rear wheels as possible, hence their aero efficiency and straight line speed, but some of the wake does hit the tyre slightly and since the Redbull is more stiffer than others the tyres heats up.
McLaren probably design their car to have more inward inwash, which allow air to flow more towards the beam-wing, promoting more downforce and that’s maybe why they’re slower on the straights. How I noticed is because of how the rear engine cover is designed that looks like exactly like the Launch-spec W13’s rear engine cover. Brake cooling was not the whole story with the MCL39 to managing rear tyre temps, it may seem it’s the overall aero package took huge inspiration from the End-season Mercedes W14 and some queues from
The W13 last year with the MCL38.
Mike Elliot was not the issue, the zeropod concept design clearly was ahead of its time. Best thing for Merc is to go back to the old rear suspension design and redesign their floor edge, front wing end plates, and sidepods. Then decide if they want the wake to go more around the rears like RBR or more inwards like the McLaren. If it were me, I would go with McLaren’s solution.
It is pretty clear the mid-wing that Merc first integrated, now on the Ferrari, McL and RB was ahead of its time. It is hard to say the Zeropod itself was a winning philosophy. The down washing and undercut engine cover geometry clearly plays a role.
Unfortunately from Merc, if like Ferrari, they have an mechanical issue at the rear then there is no quick fix. At this point, they might be best looking toward 26'. Especially if they feel the Spain TD will hit hard. Outside resolving the overheating so they can avoid a repeat in the 26' car.
The 26' engine seems to be competitive and with GE era ending, the amount of carry over will be limited. Completely changing the car as you listed this season is not feasible.
The New Front wing they're running is a TD018 compliant version, you could make the argument they were hit hard but it's more on the new rear suspension that promoted more anti-lift that caused it.
Also, I'm not suggesting that zero-pod was a winning philosophy for this regulation, I'm only highlighting what Mike Elliot thought what was important especially with how these tyres are designed and limited on cooling because of how stiff these cars run + plus the addition of the wheel covers and wheel brows doesn't make it any better, that's completely on the FIA. However in the next set of regulation, wouldn't be shocked if the concept made a return since "Inwash" is the main philosophy.
Now relating to this year, they don't need to change the car completley, just reangle the front end plates and redesign the floor edge similar to Mclaren's or Redbull for now. Sidepods could incorporate the mid-wing as well, if they want to, they could slim down the sidepod shape and minimize the undercut but that depends if they want to take that route.
Has their been clarification from the team, Allison or a reputable source that the wing was TD018 compliant. Why throw away a race to test it, when you could just do that in Spain?
I'm not well read on vehicle dynamics, maybe it is a case of tuning in the set up to correctly use the tyres but if the new geometry is not fixable with set-up then they are going nowhere regardless.
"zeropod concept design clearly was ahead of its time" led me to make that conclusion. I don't think there has been any reliable technical analysis. I thought the goal was to design such that the front tyre wake is pushed out around the rear tyres, ensuring clean flow to the diffuser but I may be misunderstanding you original post.
It they have recognized at Imola, that their direction is wrong and they were to shift to your suggesting it would be 8-10 weeks considering design, fabrication, testing. That would put them around SPA, round 13. I think at that point shifting to 26' makes sense. I also think Ferrari should move to 26' after the Silverstone upgrade. It is annoying, as at the latter part of last year we had four constructors who were relatively close. This should have been a barnstorming season but Merc and Ferrari mucked their designs and it is Max vs the two McL.
