2025 Scuderia Ferrari F1 Team
dialtone
dialtone
123
Re: 2025 Scuderia Ferrari F1 Team
Sergej wrote:I think it's quite worrying that Ferrari ran so low but failed to replicate Chinese sprint performance ?
If they have compliance issues in the suspension, plus dealing with a couple of other problems… hard to say. If the platform isn’t stable due to softness then even running low will make you pay.
Luscion
Luscion
117
deadhead
68
Luscion wrote:
01 Jun 2025, 23:04
Crazy.
The McLaren just brings these tires up to perfect temp window faster/easier?
Lots of chatter about something being wrong with LEC's car
DJ Downforce
Ham's first stint was horrendous on the used softs. He was catching up to Lec in the second: was this a case of different tyre usage or leclerc's issues? What problems did Ham have?
240
Sergej wrote:
01 Jun 2025, 22:58
I do wonder. Charles said the setup was extreme. This sounds like some workaround to bring the car lower and get it to work without grinding off the plank. It may have been a compromise to the China setup.
240
DJ Downforce wrote:
01 Jun 2025, 23:37
I think Leclerc was pushing too hard at the start. He was actually closing on Norris.
Seanspeed wrote:
01 Jun 2025, 22:31
Leclerc was slower than Lewis on his last medium stint, all while having gained like 14 seconds on him before that. So whatever Leclerc was dealing with seems to have hit him much earlier than anything Lewis dealt with.
Leclerc third stint was bad, he was getting caught by Russell and Hamilton was also gaining on him...
They were on softs vs medium.
Xyz22
Xyz22
124
I rewatched the entire race and i think i got a decent understanding of what limited Ferrari yesterday.
1 - Higher rear tyre wear compared to some of the competition: you can see Leclerc hitting a massive cliff in both stint 1 and stint 2 where the car just start sliding all over the place due to the rear tyre being completely gone. Hamilton last stint (before SC) you can see his times going up quite quickly after 5 laps (from low/mid 1.18 to 19.3 and saying to Adami that his rears were starting to go already)
2 - Lack of competitiveness with low fuel where the driver couldn't push at all, probably related to excessive plank wear fear
Sergej
Why Ferrari had bad degradation ? They never had so far this season ?
LEC definitely pushed too hard in early 2nd stint
Xyz22
Xyz22
124
Yep which usually doesn't happen. I think they didn't expect so much tyre wear on the medium.
deadhead
68
https://autoracer.it/it/vasseur-barcell ... ta-ferrari
"If we see the gaps to McLaren in the race anyway, we're not that far away, but we have to keep pushing."
am I missing something here?
Seanspeed
Seanspeed
deadhead wrote:
02 Jun 2025, 16:49
I feel like when the car is in its most optimal state and in the optimal conditions, the Ferrari is probably within a few tenths of Mclaren in race pace. But that's still a long way off in reality, and worse is that Mclaren's advantage only grows in basically any other situation because their car has like three times the working window of anybody else on the grid so basically never has any situation where they struggle.
240
So Hamilton had floor damage and the second problem is the team adjusted his front wing at one of the pit stops without consulting with him. That threw things off.
They still have to work on trusting each other.
Maybe the data is showing an adjustment is needed because the car's balance is poorer when the fuel burns down. If it's a standard thing, maybe ask how many clicks he needs first.
Note: I cannot verify the source. Saw this news on another site.
Space-heat
Space-heat
Does any one have any detail on the change to the FW the FIA required?
