2025 Canadian Grand Prix - Montreal, June 13 - 15
erudite450
erudite450
Re: 2025 Canadian Grand Prix - Montreal, June 13 - 15
The Pirelli C6 tyre is useless. They should stop bringing it to races.
SB15
SB15
erudite450 wrote:
14 Jun 2025, 00:17
This is the first time it actually lasted a whole lap before it started going away.
f1316
f1316
84
Seanspeed wrote:
13 Jun 2025, 22:50
f1316 wrote:
13 Jun 2025, 22:01
Seanspeed wrote:
13 Jun 2025, 17:56
I literally explained why it's unfair. And it's literally been tried and basically immediately reversed because it was terrible. The current situation isn't perfectly fair, but it's more fair than completely banning pitstops under a full safety car.
AGAIN, banning pitstops under VSC would certainly be an improvement, though. Because nobody is at risk of running out of fuel or anything and old tires aren't gonna blow running at low speeds. It still wouldn't be perfect as perhaps if you really do need to pit on old tires, but the race goes green right after you pass the pitlane entry and have to do an extra lap on those bad tires before pitting, but that's a minor concession to an otherwise much fairer situation.
OK not much point debating any further - you described why you thought it was unfair but not why it is more unfair than what currently occurs. Right now, someone like Leclerc in Imola has pitted early, gone aggressive, seemingly performed an undercut well and an SC messes that all up - that's also unfair. The difference is, it's unfair in a way that benefits the cars who stay out and maintain track position, as opposed to those who are aggressive and make an early stop. I'm saying that - given there will be some degree of unfairness either way, since it's pure luck when an SC comes out - why not move the person it favours to the folks who have gone aggressive and therefore incentivise early/more stops rather than later/fewer stops. This is different than we had in the past when it was tried because refuelling fundamentally changes the equation - i.e. you cannot decide to stay out if you're running out of fuel.
But it's just an idea at the end of the day and probably no chance of it happening, so not a big deal. I just don't understand why one is more fair than the other since it just moves who benefits most from luck.
It's more unfair because the penalty for getting caught out is basically an automatic race over.
If you're nearing your pit window, but then a safety car comes out and you cant pit and the entire field bunches up and then you STILL have to pit right after it goes green, you're basically automatically gonna be put into like last place, and likely with a strong gap to even get to 2nd-to-last. You could literally be in 1st place and get sent to last place because of something like this. The sheer extremities of the potential consequences are ridiculous.
Obviously it wouldn't always work like this cuz others might be in your same situation, but we still shouldn't allow for it to ever happen. This is clearly much less fair than simply gaining/losing like roughly 8 seconds or so.
Well, yes, but think about what that would actually probably mean: teams are then incentivised to pit earlier to avoid getting caught out and so therefore they push harder to make sure they use up the available speed in the tyre. Therefore not only does your extreme example probably not actual occur all that often but I’m trying to avoid it we’ve created a different, harder form of racing.
It’s like saying that now we could get a situation where someone just pitted for an undercut on lap 5 which put them right to the back and so if a safety car comes out then they would be screwed. But because of that possibility, no one goes for such extreme undercuts so the most “unfair” situation doesn’t occur. The teams will always optimise strategy vs the rules and so we need to create rules that mean that optimisation drives the most positive effect.
240
SB15 wrote:
13 Jun 2025, 19:50
Bill wrote:
13 Jun 2025, 19:46
There are people who dont want to accept that charles is crash prone
This is the unfortunate truth
I am not kicking him when he is down, but it has been said before and I got backlash when i suggested his crashes contributed to fizzling out the 2022 title fight.
Nothing wrong with crashing, but his crashing rate is a weakness. I think he pushes very hard all the time to find the limit. He is not very measured and still a little rough.
The other factor, which i sensed, is the guy in the other car. Charles has been going harder in every session versus when he was teamed with Sainz. Lewis is getting in his head a little. Charles goes all out and when he sees Lewis cannot keep up then that's when he eases off the gas and relaxes for the weekend.
Chuckjr
37
"Lewis is getting in his head a little"
My god. No he isn't. smh.
Watching F1 since 1986.
langedweil
Chuckjr wrote:
14 Jun 2025, 04:05
Posts are getting weirder by the day ..
HuggaWugga !
erudite450
erudite450
Guys, does anyone have the long run data from FP2?
search
erudite450 wrote:
14 Jun 2025, 08:52
McL, Verstappen and Mercedes all looked more or less equally fast
Not sure how to rank those Sauber times on hards.
Vettel165
My prediction.
Q3
1.Norris 2.Pia 3.Ver 4.Russel 5.Charles
Race
1.Ver 2.Norris 3.Pia 4.Charles 5.Russel.
hollus
@seanspeed, @f1316:
Make your own thread. A teken effort to talk about Canada 2025 here, please.
TANSTAAFL
venkyhere
Vettel165 wrote:
14 Jun 2025, 10:44
My prediction.
Q3
Race
I like your optimism :D
F1Krof
95
Max will masterfully win this one.
Wroom wroom
Matt2725
Matt2725
F1Krof wrote:
14 Jun 2025, 18:41
I admire the confidence but I'd be surprised.
stephen
Sometimes I get a feeling Russell focuses a lot on qualifying.
Stephen Marengo
Matt2725
Matt2725
stephen wrote:
14 Jun 2025, 19:15
He's proven enough times he has the race pace as well. Top 2-3 qualifier on the grid I would say.
