michl420
michl420
eyelid wrote:
27 Aug 2025, 14:50
Let's make it more clear shall we?
If driver lifts of the throttle, is it allowed the ICE to charge the battery then like in Toyota Prius when car is just coasting? Can the ICE still charge the battery even when demanding 100% load full throttle? Like in same time?
This is the real thrill of the rules if allowed, like replacing the hybrid turbo with more simple approach ICE straightly charging the battery, and not via complex and costly turbocharger unit.
Under full trottle, the MGUK can harvest up to 100 kw, but not instantly, just down the straight.
Part- and off-trottle, harvesting is limited by the reduced fuel flow limit there.
I suggest you download the technical regulations. Section 5.2 is of interest to you.
Edit: sorry, complet wrong.
michl420
michl420
FrukostScones wrote:
27 Aug 2025, 23:43
This is getting out of hand. :shock:
edit: maybe I'm getting old but the whole rules: Aero / PU / (and no active suspension) sound like a fever dream to me.
https://www.auto-motor-und-sport.de/fo ... ia-daten/ v
I don`t like this overregulation. Now we have specific rules for every, track, straight, overtaking, braking,.... Let the teams be individual.
wuzak
wuzak
475
michl420 wrote:
28 Aug 2025, 10:29
The rule has been update a couple of times.
The rule as at 31 July 2025 is:
C5.12.6 The driver maximum power demand must not be reduced at any greater than the rates defined below:
a. 50kW in any 1s period at Competitions where the FIA determines that the power limited distance exceeds 3500m. These Competitions and the vehicle fundamentals used for the calculation of the power limited distance may be found in the document FIA-F1-DOC-Cxxx.
b. 100kW in any 1s period at all other Competitions.
Furthermore, the total power reduction is limited to a maximum of 600kW and the resulting electrical DC power of the ERS-K must remain above −250kW.
C5.12.f The electrical DC power of the ERS‐K may not be reduced at rates greater than those specified in Article C5.12.6, unless:
  • the theoretical MGUK power resulting from reduction at rates equal to those specified in Article C5.12.6 is negative;
  • the ICE power is negative and the ERS-K power needs to be reduced further to achieve the driver demand;
  • the ERS-K power needs to be reduced further to achieve the maximum power permitted by Article C5. 2.8;
  • the driver power demand is negative;
  • a gearshift is in progress.
  • car speed is below 210kph.
michl420
michl420
That enables up to 350 kw MGUK regeneration always when the car is under 210 kph.
So they can (and will) run the ice under 210 kph always (exept of high braking zones) under heavy load?
wuzak
wuzak
475
michl420 wrote:
28 Aug 2025, 15:59
I think that refers to the ramp rate at which the MGUK power can be reduced.
michl420
michl420
wuzak wrote:
28 Aug 2025, 16:18
michl420 wrote:
28 Aug 2025, 15:59
Yes
