Aston Martin Honda AMR26 speculation thread
Re: Aston Martin Honda AMR26 speculation thread
TyreSlip wrote:
17 Dec 2025, 15:51
Wild rumour if true... solid-state batteries for the new Honda power unit?
https://it.motorsport.com/f1/news/f1-ho ... /10784997/
This would be a game changer if it worked. Without additional anode material, there would be weight and size savings with a solid-state design.
A solid state battery doesn't eliminate the anode material. It eliminates the liquid electrolyte. An "anode free" battery is another concept entirely.
Beware of T-Rex
Martin Keene
Martin Keene
zoroastar wrote:
13 Dec 2025, 03:45
FNTC wrote:
12 Dec 2025, 20:45
Damn that sounds nice (for a 1.6l turbo V6)!
yeah that sounds good. is it just me, or does it sound better than the one redbull has been using for the last few years? i have been curious to hear if the sound would chnge much under the new regs.
I hoped they would sound better with the new regs, the lack of an MGU-H sucking huge amounts of energy from the exhaust gas meant it was highly likely. Seems like it might come true.
TyreSlip
TyreSlip
23 Dec 2025, 02:10
TyreSlip wrote:
17 Dec 2025, 15:51
I never said a solid-state battery completely eliminates the anode. The best designs only use lithium metal without additional anode materials.
TyreSlip wrote:
23 Dec 2025, 15:57
23 Dec 2025, 02:10
TyreSlip wrote:
17 Dec 2025, 15:51
We won’t see a pure lithium metal anode in F1 either (imo). There are too many issues. They short circuit after some amount of cycles.
Beware of T-Rex
matteosc
matteosc
32
f1316 wrote:
22 Dec 2025, 21:35
bananapeel23 wrote:
17 Dec 2025, 16:19
FNTC wrote:
12 Dec 2025, 20:45
Wow!
The MGU-H must've been muffling the sound A LOT. This sounds a lot more raw.
TyreSlip wrote:
17 Dec 2025, 15:51
Am I right that there is no battery weight limit, only a weight limit for the PU as a whole?
Still. Batteries are very dense and sit extremely far down in the car. If it's easy to hit the engine weight floor without solid state, the benefits of the battery being replaced by a solid-state one would only really be minor packaging implications, since you can't really ballast any further down than the battery already sits.
You could theoretically load the car up with lead or tungsten ballast as far down as possible and perhaps move it around a little during setup to change the overall weight distribution, and the smaller battery would perhaps allow slightly tighter packaging, but it probably isn't a massive upgrade.
Still, it would be amazing to see solid state batteries make their way out of labs at last. If the engine weight floor is difficult to hit while maximising performance, solid state would also be a really big deal and offer huge benefits.
Maybe a slight tangent but it’s a major flaw in the regs imho to have a minimum weight limit for the PU … at all tbh but certainly one that’s easily met. Given the objective is to reduce the overall car weight - and even the modest reduction for 2026 is apparently difficult to hit - incentivising the PU manufacturers to find weight reductions seems a particularly good way to drive this down.
Imho the biggest single weight increase problem we’ve seen (anything for safety is not a ‘problem’, since that’s necessary) is the introduction of the 2014 hybrids. Perhaps, if these rumours about solid state batteries are true, Honda would instead introduce ballast to meet the regs and have an optimal weight distribution, but - again, if true, which it may well not be - really the FIA should look into reducing the minimum weight of the PU (or, indeed, abolishing altogether in order to create a real incentive for weight reduction on the engine side).
The current rules of weight reduction for the PU are to reduce cost, since there use to be a very expensive race to exotic materials to reduce weight. I agree that that would lead to a significant reduction in overall weight, but it needs to be balances with cost.
Moreover, some of the reasons we will have several PU manufacturer next year are that (1) these engines are not going to be crazy expensive and (2) they can have technology to be used in road car. I doubt that we would have more than Ferrari, Mercedes and (maybe) a third one if they were to allow a race to weight reduction. They even had to get rid of the MGU-H to get there...
f1316
89
matteosc wrote:
23 Dec 2025, 20:19
f1316 wrote:
22 Dec 2025, 21:35
bananapeel23 wrote:
17 Dec 2025, 16:19
Wow!
True, but bear in mind that any removal/reduction of a minimum weight limit would be allied with (1) a cost cap for PUs (2) regulations prohibiting the use of certain exotic materials. Within those types of constraints, the incentive of reducing weight is a good one - for example, the use case here is for lighter (solid state) batteries which is worth pursuing and is road relevant.
This Aston Martin has the most to live up to of any car. All eyes will be on this Newey machine. Will the drivers be able to hide their smiles come winter testing?! That is the true measure for me!!
NAPI10
NAPI10
31 Dec 2025, 02:46
Expectations will be high, most anticipated reveal of the season for sure.
Though, focus for AM will be to test soft & hard integrations during winter testing. Most of aero components will be revealed in Australia.
GoranF1
GoranF1
149
wiktor977
wiktor977
43
Photo from Aston's Instagram page, it looks like a triangle roll hoop shape, but hard to tell how big it is
Rumours saying the car will be late. Like possibly only getting the last test day?
madridista
wiktor977 wrote:
25 Jan 2026, 20:59
https://i.postimg.cc/4NfdZdYG/Aston-roll-hoop.jpg
from https://www.italpassion.fr/de/wettbewer ... eibende-1/
Only the Ferraris ran the triangle airbox that connects down the sides the last couple of seasons, could be something that Cardile brought over from Ferrari. I think the triangle shape inherently means less area, would have to be really big otherwise to equal a normal round inlet.
It will be interesting to see if they went as tight as possible on the sidepods like redbull, or bulky and outwashing like Ferrari and Mercedes. Just based on the inlet i guess the latter, so less cooling in the center and more in the sidepods.
Looks interesting.... :idea:
Only to get going tho.
hollus
The real car thread is open again, but please wait for actual car photos.
¡Puxa Sporting!
