Aston Martin AMR26
Stu
Re: Aston Martin AMR26
Martin Keene wrote:
11 Feb 2026, 17:08
The wiring harness is in the way for a proper look, but do you think that is a straight connection from charge cooler to inlet manifold?
In which case, as the airbox does not appear to be spilt into different sections, where is the turbo being fed from.
Using the flow through the intercooler to feed the turbo?
See here. On F1 TV the comparison starts at 45:30 minutes left.
vorticism
vorticism
449
dren wrote:
11 Feb 2026, 17:25
vorticism wrote:
11 Feb 2026, 17:20
--Expert use of zip-ties in more than one strategic location.
Added one for you.
"They've been spotted. Accelerate to Phase B."
FrukostScones
11 Feb 2026, 17:27
FrukostScones wrote:
11 Feb 2026, 17:24
11 Feb 2026, 17:17
The Aston Martin has a working front wing active aero. It was just shown on the broadcast into T1. It works.
I didnt see much working there. you mean the when they showed the comparison?
I saw it. Flap was down on the straight into T1. Then it came up in the brake zone. It's there and it works.
yeah, you are correct. pretty flat thing when up. looked for me just like normal weight shift.
Stu
vorticism wrote:
11 Feb 2026, 17:20
MtthsMlw wrote:
11 Feb 2026, 17:03
Seems to be air to air intercooler like Red Bull
https://pbs.twimg.com/media/HA4kKMZbwAA ... &name=orig
Excellent, thanks.
Looks very similar to the previous generation RB, use one damper for heave, the other for bump/rebound, use a f**king huge link between the two sides for eliminating roll. The second ‘heave device’ could be adjustment but looks to be separate from the rocker (which looks sweeet! - very organic!!), so could just be for installation stiffness.
For sure we will never see this unless there is a leak as it is not housed in the bellhousing/spacer, but around the gearbox cassette.
--fancy rockers/bellcranks
--two heave devices?
--the rearmost heave device has an airfoil shroud
--wastegate entry is visible on the tailpipe
--AMR with different weldment arrangements for their intercooler, compared to RBR (in house or supplier item?)
--they don't bother with ubiquitous divided roll hoop, instead split the ducts downstream from a single shared snorkel inlet
Martin Keene
Martin Keene
Stu wrote:
11 Feb 2026, 17:34
Martin Keene wrote:
11 Feb 2026, 17:08
Possible, but it is going to pick up a lot of additional heat, doesn't feel like an efficient way of doing it.
GSBellew
GSBellew
Stu wrote:
11 Feb 2026, 17:34
Martin Keene wrote:
11 Feb 2026, 17:08
Would that not just heat the intake air at the same time as cooling the compressed air?
Owen.C93
Owen.C93
189
GSBellew wrote:
11 Feb 2026, 18:07
Stu wrote:
11 Feb 2026, 17:34
Martin Keene wrote:
11 Feb 2026, 17:08
The flow rate would be pretty poor if you combine the inertcooler and intake, you'd have the air filter restricting the cooling flow as well.
Much easier to split the intake IMO.
dren
228
Yeah, it'd bypass the cooler section, so it's split somehow prior to cooler entry/compressor entry.
Honda!
Airbox intake looks very similar to many of his Redbull cars.. Yes the intake does not appear to be split, but inside it is split horizontally and contains two ducts, the lower one goes to the compressor mouth and the top one goes to the centerline cooling system (an intercooler in this case)
michl420
michl420
Martin Keene wrote:
11 Feb 2026, 17:08
Look closer!
BorisTheBlade
50
Scarbs already highlighted it.
https://x.com/i/status/2021595166184784329
edu2703
edu2703
37
Rikhart
Rikhart
38
Let's put some more green on that green :D
https://x.com/MsportXtra/status/2021576 ... 82001?s=20
Rikhart
Rikhart
38
From the flowviz above, I am amazed there is no sign of flow from the front wing even going near the sidepod intakes.
