venkyhere wrote: ↑15 Mar 2026, 12:35
you mean in-depth 'no look' ?
we are seeing nothing meaningful
Imo is actually more relevant now in 2026 than it would have been last year. With the introduction of Active Aerodynamics, the front suspension's role has changed.
1. Mechanical Balance for Active Aero: Because the front and rear wings now shift positions to reduce drag on straights, the mechanical 'platform' provided by this suspension must be incredibly precise to handle the sudden shifts in aero-balance. We saw even in China Lando's FW touching track at the end of straight line and producing some sparks.
2.Narrower 2026 Chassis: You can see how McLaren has packaged the upper wishbones to suit the narrower 2026 chassis width. This mounting height is key to managing the wake around the new, smaller front wheels and directing it toward the revised sidepod inlets.
3.Flow Redirection: In 2026, the goal is to manage the "outwash" differently since the floor isn't doing all the part from ground effect era.
So sorry for not having a better picture, but is all I got from the live stream.
