2026 Scuderia Ferrari HP F1 Team
mzso
mzso
75
Re: 2026 Scuderia Ferrari HP F1 Team
Just_a_fan wrote:
19 Jun 2026, 00:57
mzso wrote:
18 Jun 2026, 22:40
Just_a_fan wrote:
16 Jun 2026, 23:46
Single point of failure system - if the steering system leaks then the hydraulic system leaks. It's one system for steering, gears, etc., and the rear portion of the braking system controlled by the car (hydraulically).
Even if that is the case. It's the team's responsibility to give a driver a functioning car. Not that I see how breaking the front wing would cause a failure like this. We must have seen a hundred crashes that are like this or worse in a year, without anyone having a hydraulics failure.
So the team are deliberately breaking Charles's car are they? Because that's the alternative.
There are countless alternatives. But it's more likely they're incompetent. Either didn't fix something, or was flawed to begin with.
Not that I didn't suspect internal sabotage at Ferrari during the years. Particularly when the favorite at the time had no technical issues for many months, while the other driver suffered a technical DNF every few events. I don't think at this stage they can afford such things.
karana wrote:
18 Jun 2026, 23:40
Sidiamal wrote:
18 Jun 2026, 22:25
I was under the impression that once your fuel was homologated that was it for the season.
Fuel can be updated with ADUO
ADUO is irrelevant. They can update it freely. It requires that lengthy homologation process though.
karana
karana
mzso wrote:
19 Jun 2026, 12:16
karana wrote:
18 Jun 2026, 23:40
Sidiamal wrote:
18 Jun 2026, 22:25
I'd say Appendix C5 and Appendix C4 make it very clear that that's not true. According to the table in Appendix C4 fuel can only be upgraded for the 2027 and 2029 seasons and additionaly with ADUO .
dans79
267
mzso wrote:
19 Jun 2026, 12:16
Since we don't know what specifically failed, it could be something as simple as the crash on Saturday caused an internal crack in a rigid hydraulic line.
The line might have looked fine, but if they had run a ultrasonic test (not common at all) on it they would have seen that it has an internal fracture of some kind.
During the race the part would fatigue at an increased rate until ultimately it failed.
206 177 106 104 9 9 7
dans79
267
karana wrote:
19 Jun 2026, 13:59
Since you are so sure, please cite the specific regulations.
karana
karana
dans79 wrote:
19 Jun 2026, 14:37
karana wrote:
19 Jun 2026, 13:59
It's row 79 of the table on page 234 in Appendix C4 of the technical regulations.
Article 3.3 of Appendix C5:
For the years 2027, 2028, 2029 and 2030, upgrades to the components marked with a “check” in the
table of Appendix C4, in the relevant column for each year, may be carried out. Irrespective of
changes permitted under ADUO according to Article 3.3 of this Appendix, such upgrades must be
introduced for the first Competition of the year when they are allowed and used for the whole
Championship season.
https://www.fia.com/system/files/docume ... -05-07.pdf
sucof
39
Highly interesting sentence in Autosport article:
"Ferrari's engineers are trying to identify the cause of the issue, with it suggested that Leclerc's incident at Antony Noghes in Monaco may have had similarities to the failure experienced in Spain."
Suggesting, the same electronical failure happened in Monaco and Spain during both of Leclerc's DNF's.
f1316
89
sucof wrote:
19 Jun 2026, 15:36
Was Spain an electronic failure though? I understood it was hydraulic. Still, it could be that both were hydraulic failures? In both cases, he also crashed in qualifying though, and you wonder if those incidents could also have been part of the cause.
sucof
39
f1316 wrote:
19 Jun 2026, 22:48
sucof wrote:
19 Jun 2026, 15:36
The article seemed to suggest this is an info from Ferrari, that they were electrical.
I am sure all the hydraulic systems are controlled electronically, perhaps some of them have the pressure coming from electrical pumps even, and of course the valves are electrical too...
f1316 wrote:
19 Jun 2026, 22:48
sucof wrote:
19 Jun 2026, 15:36
He bumped the front end of the car in both qualifyings. Hard to see how that caused any electronics issues.
I can see how the Barcelona crash affected his power steering though.
Raleigh
Raleigh
29
Regardless of anything the data says Monaco race crash was caused by locking up on loose tarmac. There was no brake failure, nothing worth further discussion.
catent
Raleigh wrote:
20 Jun 2026, 14:50
Leclerc didn’t lockup during the Monaco crash. He lazily slid into the wall, fronts nor the rears ever locked, let alone appeared to meaningfully engage.
As someone who has followed Leclerc’s career fairly closely, he’s not someone who isn’t capable of taking accountability for true mistakes (such as Barcelona qualifying). If he blames the car or otherwise points to a mechanical malfunction, it’s a safe bet something was actually wrong.
And moreover, he was complaining about these same brake issues at Canada and throughout Monaco practice; this wasn’t a convenient excuse that first cropped up after an incident, but rather clearly an ongoing issue.
In fact, immediately after the Monaco crash, Leclerc took some responsibility for not changing to the CI brake discs earlier, during the Monaco weekend, since he knew these issues were ongoing, but opted to stick with the familiar Brembos to avoid any nasty surprises at a really important track to him. That Leclerc acknowledged (with the benefit of hindsight) that he should’ve switched to the CI brake discs during the Monaco weekend should 100% confirm that his brake issues at Monaco (and Canada) were entirely real and legitimate.
The state of the tarmac may have played a role but the claims that Leclerc locked up and that his brakes were functioning entirely fine - both of those things are untrue.
Raleigh
Raleigh
29
catent wrote:
20 Jun 2026, 23:59
Raleigh wrote:
20 Jun 2026, 14:50
The state of the tarmac may have played a role but your post contains two falsehoods: that Leclerc locked up and that his brakes were functioning entirely fine - both of those things are untrue.
Understeered on the loose tarmac, locked front left and hit the wall. No smoke because he is sliding on the loose tarmac and has no contact with the road.
To be completely fair, understeer from the tarmac alone was going to put Leclerc in the wall and he cannot be blamed for the track falling apart. No one seemed to pick up the cause of Stroll crashing earlier until the second crash.
Brakes being bad doesn't mean they put him in the wall, there is no evidence for any failure.
