FW17 wrote: ↑03 Jul 2026, 03:43
I guess Merc are the only people with agency to complain to the FIA on others engines
Well the deploy gray area was small and inconsequential. Merc even got Ferrari start advantage neutralized this year.
"Starting with 0 percent battery is not a lot of fun and quite dangerous," "So we're in discussions with them to see what can be done. You can see we almost had a massive shunt in Melbourne in the start, some of that is related to battery, some can happen with an anti-stall, but you can see a lot of big speed differences.
"I was not the only car that had almost no battery or 20/30%, this is something that can be easily fixed.""
That was Verstappen.
https://www.espn.co.uk/f1/story/_/id/48 ... verstappen
McLaren initially raised the issue in February at Bahrain testing via Stella.
Alpine, McLaren Merc are listed as those that voiced concerns to the FIA on the closing distance issue.
Perez, Ocon and others (Including Vers)raised awareness to the problem which the FIA examined and changed.
There was no protest or clarification by any team or driver to force any changes by the FIA (such the compression ratio test and serrated diffuser)
Hope that helps.
