On the RB version, you see a reduction of downforce when closing. So perhaps it is a small lie that their wing is failing with properly closing, but if the driver closes it a tiny bit late, can experience too much of downforce loss when trying to break and or turn, hence loosing the rear end like Verstappen did...AR3-GP wrote: ↑07 Jul 2026, 17:03Closing phase:
https://i.postimg.cc/xdb05HST/image.png
Positive value is downforce. Negative value is lift. Disclaimer: these are models, not the real thing (which is why they have different aero loads when the wing is closed). I believe we can still take the general behaviour associated with the rotation direction.
1) Both wings experience lift generation during the closing phase. Everything below the yellow line is lift (opposite of downforce).sucof wrote: ↑07 Jul 2026, 23:56On the RB version, you see a reduction of downforce when closing. So perhaps it is a small lie that their wing is failing with properly closing, but if the driver closes it a tiny bit late, can experience too much of downforce loss when trying to break and or turn, hence loosing the rear end like Verstappen did...AR3-GP wrote: ↑07 Jul 2026, 17:03Closing phase:
Kyle also seems to believe you're wrong.AR3-GP wrote: ↑07 Jul 2026, 19:01
AR3-GP wrote: ↑07 Jul 2026, 16:46But the conclusions from the study depend on the real world designs replicating the motions from simulation. Red Bull for the moment have an unreliable actuation mechanism, so the theory of having faster pressure recovery is ironically voided if the mechanics fail to close the wing fully: viewtopic.php?p=1349167#p1349167
It is not my opinion. It is a CFD simulation. You are free to disagree with it.nico5 wrote: ↑08 Jul 2026, 15:28Kyle also seems to believe you're wrong.AR3-GP wrote: ↑07 Jul 2026, 19:01
https://youtu.be/-OXWw-nqtkI?si=MmlsYvrbEXfPQVO1&t=506
True, but my argument was about what caused the crash. Drivers have to manually close these wings, hence small delays can cause huge problems.AR3-GP wrote: ↑07 Jul 2026, 23:591) Both wings experience lift generation during the closing phase. Everything below the yellow line is lift (opposite of downforce).sucof wrote: ↑07 Jul 2026, 23:56On the RB version, you see a reduction of downforce when closing. So perhaps it is a small lie that their wing is failing with properly closing, but if the driver closes it a tiny bit late, can experience too much of downforce loss when trying to break and or turn, hence loosing the rear end like Verstappen did...AR3-GP wrote: ↑07 Jul 2026, 17:03Closing phase:
https://i.postimg.cc/ZR2S5WrM/image.png
2) viewtopic.php?p=1349167#p1349167
The footage from Austria demonstrated this. viewtopic.php?p=1349167#p1349167Viaplay: So what happened there?
Max: "Same as in Austria, rear wing didn't close entirely."
I'm wondering if this mechanical failure is due to the conditions present when closing "late" into a high-speed corner. Aero loads can shift pretty dramatically when under yaw conditions, so maybe closing SLM early on certain corners would solve RBR's problems?
