2026 Mercedes-AMG Petronas F1 Team
gearboxtrouble
gearboxtrouble
Re: 2026 Mercedes-AMG Petronas F1 Team
26 Jul 2026, 18:04
Toto Wolff on blue flags in Hungary: "The problem is that some engineers on the pit wall are absolute Teletubbies and would rather stare up at the sky than tell their drivers that there’s a train of leading drivers coming from behind and that they’re fighting for positions."
Quote of the weekend. :lol:
I wonder if he confused Muppets and Teletubbies lol.
zibby43
zibby43
gearboxtrouble wrote:
26 Jul 2026, 20:16
26 Jul 2026, 18:04
I think he may have nailed it with Teletubbies because in the interview, he said something to the effect of, and I'm paraphrasing, "mute like Teletubbies." I know what a Teletubby is but I have never seen it so if they're not mute, then maybe that wasn't the proper comparison lol.
MB_Racer
MB_Racer
zibby43 wrote:
26 Jul 2026, 20:15
Ferrari really threw us a lifeline this weekend. Kimi extended his lead in the WDC and basically kept the WCC frozen in place.
Damage limitation heading into the summer rather than limping into the summer. Team should be very motivated to come back strong after the break.
Exactly! Well summed up.
Great job by Kimi, and only one point lost to Ferrari in the Constructors’ Championship.
That’s excellent damage limitation considering the horrible grid position!
Waz
Waz
Kimi is driving really maturely in the last 2 races. He's lost the teen angst from earlier in the year when he wasn't in the lead.
clownfish
26 Jul 2026, 17:12
edited: Antonelli explained what happened to Russell. The battery was topped up too much which meant the turbo could no longer build boost (it needs to be able to load the engine against the MGUK in order to build boost). Without boost, the car had no power and went to anti-stall when the dropped the clutch.
Here's what George said
"I was on the throttle holding the revs, and then all of a sudden, about four seconds before the lights went out, the engine just started revving all over the place," Russell said. "I was reacting with my throttle, and it was doing nothing. So, the engine wasn't reacting to the throttle."
https://www.espn.co.uk/f1/story/_/id/49 ... ungaroring
Plausible it could have been caused by the ers failing to provide the expected load.
Lasssept
137
clownfish wrote:
27 Jul 2026, 14:16
26 Jul 2026, 17:12
I agree I think there is a connection between the ERS no longer charging, and the revs rising. Motorsport.com posted some telemetry. Antonelli seemed to know right away what it was, so it's likely that they have experienced this before on the Merc PU.
Beware of T-Rex
Farnborough
Farnborough
152
27 Jul 2026, 15:08
clownfish wrote:
27 Jul 2026, 14:16
26 Jul 2026, 17:12
https://i.redd.it/rqz9wpls9rfh1.png
If the ERS has to drop loading, because its full (Antonelli word was "stack" full, I thought) then ICE will show that to GR in feel. He responded by taking foot off throttle, boost from Turbo was, correctly, quenched. Lights out and GR releases clutch against expected ICE under boost load, to find it's not available. Traction then triggers anti stall, by pulling clutch to make available "go again" then you could see how long the turbo lag took to reduce as everyone keeps sweeping by GR.
Looks like GR got the final approach wrong, that to overfill the battery prior to start routine demand that's used to build boost.
Don't feel there's mystery "control" but circumstances tripped over by driver.
Farnborough wrote:
27 Jul 2026, 15:26
27 Jul 2026, 15:08
clownfish wrote:
27 Jul 2026, 14:16
On the surface yes it would seem that the battery pack (aka Energy Store/ES) became full (for some reason). Whether that's on the driver or not is hard to say with these PUs. If he began the pre-start procedure too early, then yes that would be his fault, but if there was software issue in the formation lap then it might not be.
Beware of T-Rex
Farnborough
Farnborough
152
I can see that, and discussion about procedure and effectiveness of that against resources during pre start routine valid.
But don't see conspiracy in what happened with throttle as load come off in final seconds before launch. Looks like the result was entirely logical once the energy store was maxed out, at which point it could no longer reasonably be used as brake to run turbo boost accumulation against.
Brahmal
Brahmal
92
Farnborough wrote:
27 Jul 2026, 15:50
I am not an electrical engineer, but there must be some way to safely discharge that excess energy instead of just shutting down the generator side, no? Putting a tesla coil on top of the camera pylon comes to mind, and yes I know that is a very dumb idea but you get my drift. :)
Farnborough
Farnborough
152
Brahmal wrote:
27 Jul 2026, 20:42
Farnborough wrote:
27 Jul 2026, 15:50
Me neither, but anything to dissipate the energy would just add another thing to this rules farce built around that notional 50% dream.
There was obviously good facility in last reg set either MGU-K that could spin turbine on demand for just situation like this, but well recorded politics with new entrants nixed that effective device.
Reading between lines, along with Antonelli confirmation, GR should have arrived with planned capacity to accommodate this routine, but somehow didn't.
A dangerous situation also for GR and following drivers. Not really acceptable by most measures, considering warnings were given by seasoned key participants prior to this season start. It's really just a mess, isn't it.
They've even given allowance (i think I understand that correctly) to use E bellow the normal deployment threshold in trying to mitigate this danger. Just more rules on top of more rules that shouldn't be needed.
venkyhere
45
Just adding explanation to @Farnborough's above post for the sake of people without an engineering background :
"topping-the-pack and still applying throttle causing boost loss"
is the same reason why an electrical generator needs to have a speed governor for the mechanical source that turns the rotor.
While applying full throttle, if there is no load current (charging current in this case drops to 0 when battery becomes full) => no load torque on rotor => mechanical 'runaway' - tremendous acceleration of the rotor (alongwith mega voltage build up on the stator beyond dielectric/insulation limits) that can cause the bearings and mechanical assembly to fail, apart from an unsafe high voltage buildup.
Solution ? Just like speed governor for the turbine in a power generation plant, 'turbo is the speed governor' for the grid start condition, and the boost has to be reduced to protect the car.
This whole mess is because MGU-H was removed. When MGU-H was there, the MGU-K 's generated output could be used to spin the MGU-H itself (by minimizing use of exhaust gas and maximising use of electricity to spin the turbo) and avoid the 'no load current' scenario. Benefit was not just the already topped up battery, but also a high-boost maintaining turbo.
Brahmal
Brahmal
92
Would it be possible to discharge excess electricity into the track surface? Either through a hanging brush/wire or via the plank and skid blocks? Another very dumb idea I'm sure, but I have a portable dust-extractor that discharges static electricity exactly this way. Orders of magnitude more energy here though.
Farnborough
Farnborough
152
Reasonable overview here to include in discussion
You can watch in real time, plus comparison with more successful application of routine needed.
