Giblet wrote:Pit lane begins at the speed line, where cares have to slow down.
Nope. The pit lane exit isn't denoted by the speed line either. If you have a rule or regulation you can point to (as you have demanded yourself so often) where that is the case and backs up what you say then I'm all ears, and eyes, but you haven't produced one.
Interestingly, the appendix L portion of the code makes reference to the pit lane entry but not much about the exit, although we do know drivers have been penalised for going over white lines on the pit lane exit. Is there a ruling somewhere that covers that one anyone?
The pit lane, and pit entry are separate entities. That is the whole basis of this problem, as discussed very early on.
Nope, I'm afraid they're not, but alas, the only option open to you now is to argue that they are.
You are getting the two terms mixed up in your head.
Nope. You want them to be separate, but from what we've seen there is no evidence that they are. It's a red herring.
You've argued several strawmans and red herrings:
1. That all four of Hamilton's wheels weren't over the white line, therefore it was all OK. There is pictorial evidence that says all four wheels were over the line of the pit lane entry - even though there is no such ruling about 'four wheels'! It's if you drive anywhere outside of the pit area to gain entrance, or exit.
2. It was OK because Hamilton entered the pit lane from an off-track area, so presumably because he wasn't actually on the track it was then OK.
We don't seem to have seen or heard of that theory again.
3. Even though you've made previous arguments based on the pit lane entry and the white lines that designate it, you now completely ignore them as being a part of the pit lane at all even though there is no ruling that the pit lane begins and ends at the speed line although pit lane entry (and exit) and the track
4. Finally, obviously if you ignore the pit lane entry area then you have the problem of the pit lane exit. The only option left is to argue that both are somehow different when there is no ruling anywhere that we have seen that says that they are.
